Hi to all i am new to the forum and own a R32 gtr and have heard lots of different advice from various performance mechanics in the know about how strong a gtr box is.
I am putting a plea out to all the real experienced owners of angry skylines to please give me some real life advice as to what sort of power they are running through these gearboxes and what they can handle if driven with some sort of decency.
My car is running a 12.4sec quarter mile and i was told that from here on any lower times with these boxes is just luck of the draw, i have a heavy duty organic clutch and consider myself a decent driver not a rev dumper of big power as some might do.
Can these boxes hold out comfortable in the mid to low elevens which is the target i am happy to achieve and will this gearbox be up to the task, any experienced advice will be most appreciated thanks to all that read and pass on any info for me.
Cheers Dave.
Edited by GTR 400
https://www.sau.com.au/forums/topic/183418-r32-gtr-gearbox-how-strong-are-they/
Hey,
I've got an R32 GTR with 270 4wkw putting it to the ground through 255 tyres on all corners and my box is holding up fine, I think that sort of power is good for an 11 pass...not sure as I havent put her down the strip yet. Putting a high quality oil like redline in your box might help prolong wear and smoothen the shifts a bit and like you said, don't do any high rev dumps.
Cheers!
Gagz
Edited by R31 Gagz
On standard cermamic turbos,1 bar making 260rwkw . I have done over 200 11sec passes...mostly all in the 11.5-11.6 range. That launching the car hard on powerfc pro launch control set at 7200rpm. Used redline shockproof oil (red) and os tripple plate clutch.Didnt have one problem with the box, for 2years...drove it on the street/drag. Still in the car now, but hasnt run in 5years..mock up box for my drag car.
The only thing that is an issue in my r32 GTR box is when I shift from 5th down to 4th it will crunch/grind a little. Car is basically stock atm 208rwkw but will be pushing 300+ next week so if she blows Ill let you no. :nyaanyaa:
Ryan
Thanks guys for all your replys, it is good to know that with low elevens my quarter mile target i should be ok with the standard box, has any one else achieved an awesome quarter mile time through the factory gearbox that would be an interesting bit of knowledge to obtain to see what limits some people have been able to go with the factory box.
Cheers,
Dave.
Holy Cow really 10 sec GTRs on standard boxes thats incredible dont mean not to believe but any one who belongs to the forum who has done this with the standard box please stand up and tell us haha.
My mate did a 10sec pass in mine standard gtr box. Most 10sec gtrs here in NZ are running factory gtr boxs. Most of them arnt street legal because of import laws.
i didnt really believe it either.. ive heard and read about.. dont actually know anyone who runs 10s with stock box.. but if u do.. damn impressive.. i think durability is all about how u launch and shift.. if arent too hard on the box then it should last... i guess
Generally when you get over 300-330rwkw then things start to stress a bit more than the gearbox sometimes is willing to take on.
Also original condition of the box does play a fair part in it aswell.
Stock turbo'd GTR's tend to never have issues.
Its once you head towards 340/360rwkw and thumping launches with some traction that things tend to no be so happy, and 3rd gear is common
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
