whats that convert to "Hg ??
If we're still talking absolute then its 30 in/hg. google "kpa in/hg conversion" and hit "i'm feeling lucky"...(duh)
If you're talking gauge, then 0 is 0 in any unit....
  • Replies 682
I heard you're offering drives in your car at power cruise... is it cool if you watch from sidelines? I want to take some friends down the straight... thanks champ
but srsly, gimme a passenger if i go, I've only ever seen this thing on the dyno...
what sort of rpm are u gonna spin this motor upto Paul? i assume your running the external oil pump setup too? I also run the similiar cams from what the specs posted on the last page were anyway, and my vacuum is about 6 below the 0 mark on my autometer boost gauge at idle and made for some real bad braking issues.
ill rev it to 9000 on pump...no more yet. Normally i like to see 9500rpm when racing with better fuel before i shift, as its still making power and good torque at that level.
Still running a JUN oil pump...no external yet.
Edited by DiRTgarage
did a nice safe tune for pump. The car was making 450KW or 600hp at around 21psi, a nice 11.5 AFR with the timing advanced 17degrees. The turbo makes full boost by 5500rpm with the external gate spring pressure only (no electronic boost control). Rev's were limited to 8500rpm, so with some race fuel, a leaner mixture, some more ignition advance, another 14psi of boost and some NOS...this things going to really move.
Big thanks to the Guilt-Tripper for crunching the numbers into the Vi-PEC V88...a great job done mate.
Yeah it was a long day.. Lots of work was done to the car to prepare it for the Dyno. I was pretty fussy and was starting to annoy paul with some of the requests before i was ready to tune it. Everything got sorted out and we only had a few hours left to tune it.
This car is awesome. So tough its just amazing how good the engine is, you can tell that it was built by a true professional *cough paul Red R Racing cough* lol :P
The gearbox took a bit to get used too, I connected Mark @ Godzilla Motorsport to have a look at the map and give it a once over before going over 4000rpm and we had a couple of things that needed to be changed, after Mark was happy with the setup it was smooth sailing all the way.. There was only a couple of videos taken because Paul was too busy making sure the turbo drain was not leaking, just as we were ready to start power runs it was decided to stop and fix the issue before taking the revs up anymore.
Here are some pics, and Videos
Niiiice!
What AFR's will you aim at as a max on pump98?
Where its at now...this tune is only set-up to run around town...im not interested in running the engine any harder on pump. Ive built this car run times as its main goal, to achieve this the engine will have to be reasonably stressed to make the power required. The ultra consistent (and ultra expensive) leaded fuel we will be using is the only petrol based product that is capable of supporting the power at a reduced risk of engine damage. To unnecessarily push the engine on an unleaded fuel is a waste of time and money. This is why we limited ourselves to the parameters Mark set when tuning it, i.e. 8500RPM 11.5AFR 24psi and 18deg. We actually tuned it under all these levels as they were advised as a maximum and not a target to reach.
Mark will be coming down next month to perform a full race fuel tune and help prep the car for the upcoming Sport Compact drag event in Sydney. He seems to think around 35psi+ is where this turbo will see the real power made. We have the spray as a back-up if the power is not quite where we think it needs to be.
We changed to a different style of plug today and did a few runs. It instantly made a 15KW gain and the engine actually netted an increase of 1psi in boost due to improved combustion. Nice
465KW to run around town on is enough to have fun with.
Guilt-Toy has got some vids to post up...i forgot to grab a print of the curve before i left today...will grab one tomm.
Well done on the results on such little boost paul, should make big power when you turn it up and tune on better fuel.
Interesting results you got from that plug change, what were the 2 different plugs?
thanks sky...the result was only 2kw short of its best ever pump fuel figure. Considering how hard we used to push the pump fuel tunes its really impressive to almost top the figure given the limits set.
the plugs were everyones favorite BCPR7ES's....we ran something colder with different style electrode...even they were not the optimum plug for the application.
i still think the plugs were not the problem why it was breaking down. i think it was the really hot fuel in the tank
Stace says it was the plugs
It only did it when we went for more boost and sounded awfully like ignition breakdown so im tending to agree with her. Disagreeing with Stace is not a smart practice. :P
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
