  • Replies 682
the GT-RS graph is in 3rd gear so no direct comparson available which is a little disapointing. When i get the 4WD sorted ill take it up for a 3rd gear 4wd run as im just as interested as you Steve-o. The 3rd gear run in rwd just fry's the tyres.
ashamed of high-flow lag...never. Im totally aware of what im doing and know exactly whats needed. Yes ill have knocked a large hole in my torque curve...but that was expected. Peak torque at 7000rpm is whats needed to run the numbers at the strip not 4500rpm like before.
Wayne is going to rescale the graph for me...as soon as he calls me ill go and pick it up.
Edited by DiRTgarage
Ok so obviously still no 4wd... So did you find out if the problem was what you thought it would be Paul?
would be interesting to see a side by side of your GT-RS graph vs his GT-RS graph.
Yeah would be, but Paul will have higher numbers i suspect due to cams and porting differences. Mine would probably bring them on faster with greater torque. Time will tell :D And its getting the fuel system done right now, so the tune isnt far off
Cool :thumbsup:
He still plays with carby's and pushrod engines...i think i don't need to say anymore.
nah he is really into his Wolf V500 ecu's.. he loved them to death. Wayne is getting really good with aftermarket ecu's now.
He has actually sold quite a few / installed and tuned himself. They are doing really well over there now.
The Dirt man has been admitted to hospital :D I hope its not too serious but I will keep everyone updated as soon as i hear anything :) I just rang him to tell him I finally uploaded a video but Stace answered the phone to tell me the bad news :)
Its not because of the reason he was sick last time either. This is un-related.
Here is the video. anyways... Hope you get well soon Paul
Video is still new - should be up soon
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
