Strange carbon brakes front and rear.
paul, are these disc's purely for drag or suitable for circuit?
what is the main advantage here, weight or stopping power? they use carbon dics's on race bikes but they have an outer heat shield which retains heat otherwise they dont work well when the carbon is cold
  • Replies 682
Drag only Marko...weight saving and awesome stopping power. Pulling up from 240km/h generates the heat required...only good for one or two big stops.
is that a realy cost effective way of doing it then or is that basically your only option. part and parcel.
with small rims for the drag radials big brakes are not able to be fitted. They are heavy also and are unsprung weight. It can shed some valuable kilo's without haing to hack the car up. Im struggling to pull the car up with the stock R32 brakes as well. The parachute will be fitted but pulling it and packing it after every run is a pain also. The brakes came at a good price and will allow me to 'donate' the GTR brakes to my S13 project car.
Edited by DiRTgarage
  • 4 weeks later...
Ran 9.5 last night at Willowbank at a lowly 126 MPH. The clutch air gap was too small locking me out of 4th gear in the deep end. Ran 114 MPH to 1/2 track and 60'ed a 1.37. So to run a 9.5 with 20 MPH+ washed off the terminal speed is rather encouraging.
Big thanks to Mark and the team at Godzilla.
The brakes and chute arrived in QLD today and will be fitted before the next meet.
Bring on Jambo!
fark yeah - it almost sounds like u could crack an 8 :D
considering it only put on 12 MPH from 1/2 track onwards and normally puts on about 34 MPH id say that pass was a VERY LOW 9.
8's have always been the plan.
once we get a few consistent clean passes out of it we can throw a bit more boost at it and see.
any footage or pics?
Just Dave took plenty of snaps. Someone may have taken a vid...but no-one in our crew.
Also big thanks to all you guys on here for the support and interest in the car...its much appreciated.
cheers
drag radials?? WTF?? parachute?? WTF?? Small rims?? WTF?? is all this air lock transmission crap and shit really worth it to go from 9's to 8's??
give me a gtr that can drive to the track, belt out a 9, and drive home again anyday over a fully prepared 8 sec drag car.
lol...i was planning to drop the car where i was staying at a friends place at Birkdale and drive the car to Wakerley this morning in the same spec it was ran last night. Mark was kind enough to open the shop at 11pm last night so i could drop it off at Godzilla.
The car is actually nicer on the road with all the new mods except the whine from the dogbox...but once your in 4th you dont hear it as its 1:1.
Thanks for your post...nice.
EDIT: ill be kind enough to answer your question...f**ken oath its worth it!
Dirt , if your trap speed is normally around 148 mph i would say a perfect run would have been a 9.1 ...& the 60ft seems to be on the money.
You are very close to the 8 sec barrier & if the car can 60ft even better i would say a 8.9 is on the cards...you seem to be making enough power to do so.
Congrats on a very nice car that is also that quick & hope to see you get the elusive 8 sec time card..it wont be to far off !
Im all for keeping it as much a streeter as possible too.
Cheers ezy, that track was a street meet...next weekend is Jamboree which will be a full prep so id say the 60 may fall even further.
great to hear the new setup looks like running it's potential. good luck with jambo its great to see sau-ers competing at a national level
thanks Dunc's, third time lucky with the new set-up. We found a small problem that took 5 mins to repair, it instantly rectified the cars inability to launch properly. Fixed it and bingo the car runs a number. A little way to go yet but we are getting on top of it.
Bring on Jambo!
i always though people had dog box's for clutchless shifting ? so no clutch air gap keeping you out of fourth
maybe also need some better quality hose clamps maybe wiggins clamps
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
    • There is a warning that "this thread is super old" but they ignore that anyway...
    • With 10% Ethanol, we're talking 2-3% fuel consumption difference. The emissions reductions and octane boost in my opinion far outweigh this almost non existent loss.    My tanks sitting at 80%. Luckily that should go down fast as I'm on vacation again for the next two weeks.
