Strange carbon brakes front and rear.
paul, are these disc's purely for drag or suitable for circuit?
what is the main advantage here, weight or stopping power? they use carbon dics's on race bikes but they have an outer heat shield which retains heat otherwise they dont work well when the carbon is cold
  • Replies 682
Drag only Marko...weight saving and awesome stopping power. Pulling up from 240km/h generates the heat required...only good for one or two big stops.
is that a realy cost effective way of doing it then or is that basically your only option. part and parcel.
with small rims for the drag radials big brakes are not able to be fitted. They are heavy also and are unsprung weight. It can shed some valuable kilo's without haing to hack the car up. Im struggling to pull the car up with the stock R32 brakes as well. The parachute will be fitted but pulling it and packing it after every run is a pain also. The brakes came at a good price and will allow me to 'donate' the GTR brakes to my S13 project car.
Edited by DiRTgarage
  • 4 weeks later...
Ran 9.5 last night at Willowbank at a lowly 126 MPH. The clutch air gap was too small locking me out of 4th gear in the deep end. Ran 114 MPH to 1/2 track and 60'ed a 1.37. So to run a 9.5 with 20 MPH+ washed off the terminal speed is rather encouraging.
Big thanks to Mark and the team at Godzilla.
The brakes and chute arrived in QLD today and will be fitted before the next meet.
Bring on Jambo!
fark yeah - it almost sounds like u could crack an 8 :D
considering it only put on 12 MPH from 1/2 track onwards and normally puts on about 34 MPH id say that pass was a VERY LOW 9.
8's have always been the plan.
once we get a few consistent clean passes out of it we can throw a bit more boost at it and see.
any footage or pics?
Just Dave took plenty of snaps. Someone may have taken a vid...but no-one in our crew.
Also big thanks to all you guys on here for the support and interest in the car...its much appreciated.
cheers
drag radials?? WTF?? parachute?? WTF?? Small rims?? WTF?? is all this air lock transmission crap and shit really worth it to go from 9's to 8's??
give me a gtr that can drive to the track, belt out a 9, and drive home again anyday over a fully prepared 8 sec drag car.
lol...i was planning to drop the car where i was staying at a friends place at Birkdale and drive the car to Wakerley this morning in the same spec it was ran last night. Mark was kind enough to open the shop at 11pm last night so i could drop it off at Godzilla.
The car is actually nicer on the road with all the new mods except the whine from the dogbox...but once your in 4th you dont hear it as its 1:1.
Thanks for your post...nice.
EDIT: ill be kind enough to answer your question...f**ken oath its worth it!
Dirt , if your trap speed is normally around 148 mph i would say a perfect run would have been a 9.1 ...& the 60ft seems to be on the money.
You are very close to the 8 sec barrier & if the car can 60ft even better i would say a 8.9 is on the cards...you seem to be making enough power to do so.
Congrats on a very nice car that is also that quick & hope to see you get the elusive 8 sec time card..it wont be to far off !
Im all for keeping it as much a streeter as possible too.
Cheers ezy, that track was a street meet...next weekend is Jamboree which will be a full prep so id say the 60 may fall even further.
great to hear the new setup looks like running it's potential. good luck with jambo its great to see sau-ers competing at a national level
thanks Dunc's, third time lucky with the new set-up. We found a small problem that took 5 mins to repair, it instantly rectified the cars inability to launch properly. Fixed it and bingo the car runs a number. A little way to go yet but we are getting on top of it.
Bring on Jambo!
i always though people had dog box's for clutchless shifting ? so no clutch air gap keeping you out of fourth
maybe also need some better quality hose clamps maybe wiggins clamps
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
