  • Replies 682
  DiRTgarage said:
thanks mate...a vid of the 9.4
fark me!
that is the best angle to take footage from - except that twoogle disappears in the distance
what a launch, cannot beat the sound of a gtr IMO
  NYTSKY said:
Jeez Paul, that seemed effortless!
Sounds horn too!
yeah was a pretty easy pass...1st one with everything in order. Clutch was used in all shifts...time to turn the boost up, tweak the suspension settings and stop using the clutch.
  • 1 month later...
  Marko R1 said:
what mods have u made paul? bigger turbo HAHA
nothing yet...arrive back in qld on monday and ill start sorting a few things out that should see some good gains. Nothing crazy the set-up will be pretty much the same as i believe now all the car needs is a few tweaks...we are going to try a few things in regards to fuel, boost control and suspension.
  • 1 month later...
Righteo...just a quick update...new fuel system and wheel speed based boost control system installed. Mark will be back from the states tomm. so it will be on the dyno very soon for tuning.
Ive entered the Aust vs USA Nitro funny car 2 event series on the 2nd and 16th of January at Willowbank. They have grouped Super Compact with Competition Eliminator bracket and have me racing dragsters and doorslammers. I have resigned myself to be swiftly knocked out of the 1st round of eliminations as my index for my class (Super Compact AA/SM) is 8.38. Should be good fun racing against some big cars running 6's and 7's.
Edited by DiRTgarage
  TiTAN said:
time to get the slicks out and make use of that little blue bottle?
slicks and NOS have no place on a street car :P . It will be fun getting smashed by Austraila's best. The sound of a low 6 second doorslammer passing me at the 330ft mark may leave a nasty stain in my racesuit though :) .
  DiRTgarage said:
slicks and NOS have no place on a street car :woot: . It will be fun getting smashed by Austraila's best. The sound of a low 6 second doorslammer passing me at the 330ft mark may leave a nasty stain in my racesuit though :) .
How oftren do you actually drive it on the street (serious question)?
whenever i feel like scaring myself...its mental on the Toyo road rubber...low boost and 1/2 throttle is all you can really give it without becoming part of the scenery. Since the car has been based in qld i haven't had much of a chance to go cruising in it...but once it goes back home it will be taken for a road run whenever i get time.
The car is reasonably well kitted out for road duties as only the rear trims and seat have been removed. It still retains all factory front trims and controls. Even the front and under car sound deadening remains and all the glass is factory as well as power windows. Its pretty much all there except the rear trims and seats as previously mentioned, the air con and the stereo.
Its road registered, runs plates, its a full bodied car, is only marginally lighter than a standard car, runs street radials and doesn't use nitrous. It was fully legal to run as a street car in the ANDRA sport compact drag series, the rules were fairly strict and even stated you couldn't remove the roof lining or carpet.
Ben Bray 3000hp 2700lb Top Doorslammer vs Paul Diemar 1000hp 3400lb Street GTR
Its going to be a massacre!!
Come on softy... he's only got 3.5 SECONDS and 100MPH on you!
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
