is that the 613?
its a 612....
greg, i think its the same one that drove past us when u dropped by my work.
saw a couple of mustangs and saleens in the mustang australia store when i walked past on an errand for work...damn hot cars.
i saw probly around a '91 318i BMW with clear tail lights and a HKS power badge on it
Does that count??? :(
if you count brushing your teeth as foreplay!
haha..jus got that off the simpsons :(
Then a few weeks back spotted convertible gallardo
that belongs to the P1 car club- i've been in it while it was being caned ;)
it sounds teh awesome
p.s i've seen that black 612 Scaglietti about 5 times- it's a city regular
todays collection
i give the car 10/10 (love that electric blue), and the cutie that got out of it gets 9.5/10
down at Prestons
sorry about losing the front of the Phantom- I didn't get the cam ready quick enough
first blinged one I've seen, Hyde Park
