  • 4 weeks later...
Casino foyer
Military road in Mosman. Carbon-fibre side-blade looked awesome in real life.
Just now coming across the harbour bridge. Couldn't believe it- An F430 Spider and a 599GTB (in red circle, couldn't get a good shot). Sorry about crappy night photos.
Oh, also spotted the same Gemballa-spec'd Porsche Cayenne twice on Thursday arvo - once parked in Seven Hills, and then about three hours later on in Liverpool on the Hume Highway heading towards Casula.
More then you can afford pal!
I saw the same Ferrari twice today... once in Hornsby at like 10 when I was in the line, then the same on in Pymble at like 1pm when i was in a dif car...
what are the odds of that!
Pretty rare, just like this - two completely different areas!
I spotted a darkish-grey Audi R8 on my way into Parra this arvo. The LEDs it uses for the DRLs are damned bright, even in broad daylight!
I tell you what, the thing pulls looks from left, right and centre. As I drove through the main strip of Church Street with it driving directly behind me, about 80% of the people around turned to look and stare at it.
Hot looking car, but I think the grey took some of the appeal away for me. It might have been dirty, but the colour looked dull for such a nice looking car.
I think I spotted the same grey LP640 as pictured above in Chatswood on Saturday night.. Picked up a guy out the front of Hoyts and gave it a belt through the tunnel. Sounded sublime!
isn't Hoyts on the 4th or 5th level? lol
Outside the stupidly steep escalator that goes straight from the road up to Hoyts level, under the tunnel thing underneath westfield... The escalator has got a Hoyts sign above it.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
