saw a black Ferrari 458 italia in the city todayon Sussex street in Sydney CBD. Wish I could have gotten a photo but was driving. Must be one of the first in Australia??
Yup, it was the first in AUstralia, it is the demo that Italia Motori use for product launch, test drives, something for buyers to look at. Was it around lunch time? They usually drive it up to the CBD for appointments for test drives by ceo's and what not...
Oh, I spotted a wine-red late-model Lotus Esprit (possibly a V8) somewhere between Castle Hill and Baulkham Hills last Friday - can't remember exactly where, unfortunately.
Such a cool car
The TT ones don't have bucket loads of power but it's SO nice inside
Plus the noise they make at idle is to die for
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
