Okay. I’ve had this RB25 in the car for a while. I did the conversion myself but Ive done many others with success. The car runs like a champ, doesnt miss a beat and starts fine. No codes come up on the ECU and I have plugged in the Nissan consult and everything seems fine. Timing is good, TPS is good and I have even gone thro every sensor diagnosis procedure listed in the factory Nissan service manual.
Now the car sounds fine driving like a normal person but when your foot gets heavy and you want to go fast it just sounds like the exhaust is plugged up or something. I have normal power in low RPM but when I get up to 4000RPM it just feels held back. The engine sounds fine but you can tell by the exhaust note that’s is just not right.
I had a RB30 in the car before and it sorta felt like it had the same problem. I didn’t think much of it though as I was swapping in the RB25 so I could sell the car but thinking it was the same problem as the previous engine I thought it could be something wrong with the cars components like intercooler, exhaust and fuel system. So I unbolted the exhaust and took it for a rip and was still slow. I checked fuel pressure, changed the filter and upgraded to a high flow pump and still slow. Then I took the intercooler out and tested it and cleaned it out with cleaner and still slow. I have took apart the entire engine harness and pretty much rebuilt it. I did find a bad ground for the o2,TPS and AAC so fixed that but still the car is still slow.
I have done a basic tune up as well like plugs, packed the coils, fluids ect. I have also took the intake off the turbo to see if my turbo was still moving freely and seems just fine though one thing I haven’t checked was if the exhaust blades are still on the turbo but I still build boost like normal so didn’t think that was necessary. I have ign timing set right at 15 deg. Another thing that isn’t hooked up is the neutral switch to the ECU. Is this a problem??? I have done other rb26 conversions without neutral signals in race cars and they were fine with factory rom tuned ecu’s
This problem is going to be retarded, I know. Something really simple but I am running out of ideas. If you guys can think of anything I can check over please let me know. Any tips are appreciated. ;)
Edited by RB30 Ceffy
https://www.sau.com.au/forums/topic/184352-slow-rb25-need-help-please/
Slow is relative.
Now you've spent quite some time and still feel it is running weak at higher rpm and load, you should really have little problem buying 30mins of dyno time. It should provide some additional insight as to whether it really is running weak, or if you need to be reassessing what is slow or not.
Well I guess I have to hope you can take my word on this one. I personally dont need dyno time to tell me its a slow car and down on HP. A factory rb20 can eat this alive right now :( Ive done over a duzon other rb25 conversions and this one just doesnt cut it unfortunatly. But I see where your coming from. Dyno sheet would help me see where the problem might be coming from. If all is bad I might have to consider this but I dont see how I should be able to fix this in the shop. Thanks!
what about the diff ratio ?
what gearbox are you using?
remember rb25's in skylines had 4.11:1 and 4.39:1
in australia people make the mistake of putting the rb25 into the VL Commodore with the stock 3.45 ratio or whatever it is and wonder why its slow as hell but it will go up to 200ks an hour in third gear.
check your ratio's!!!
i'm having the exact same problem. everything runs right but the power is not as what an RB25DET is supposed to provide... boost reads nearly 1 bar on the boost meter but feels like RB25DE.
if Guilt-Toy is right, then i might have to change to a stock RB25 rear diff as i'm running stock Z31 300ZXT auto rear diff, 200kmh @ nearly 6500rpm @ 5th gear...
Car is a A31 Cefiro. Diff is a factory A31 unit. 4.11:1 diff and RB25 trans. The gearing is as normal as any other factory nissan.
I have changed the factory fuel pump with a nismo unit to see if that was my problem about a month ago. Pressure is fine and all lines are normal. Changed the filter aswell. Still the same after all this.
Ignition is fine, coils are mint, 180 and 1 deg signals from CAS is good. Timing is fine.
I have tried to advance the timing 5 deg and still slow. I tried to boost the thing to 1 bar and still slow.
That diff ratio seems short and it will make the car feel faster because it will be accelerating quickly.
;):(:D:(
Take your CAT out and check it. maybe its blocked? do you have any air leaks in the piping when on boost? maybe it only leaks on boost ?
have you put it on the dyno and checked the air fuel ratio ? i would be doing this after checking the turbo and cat
cat is fine.Dont need cat's where Im from :P
But ya. I guess I will dyno it and see what I can come up with. I dont have any boost leaks. All pipeing is fine and pressure tested it just a couple weeks ago to make sure. Didnt leak to 80PSI so thats good :D
Im going to book a dyno run maybe later this week if I have time. I was thinking along the same line as you acsplit. It feels like it pulls timing up top. Thats what made me think I had a sensor on the fritz but Ive checked it all and nothing comes up on the consult. I also thaught that the 25 would need the factory boost control solenoid. So I tried to plug that back in and with it not in and still ran the same either way. Confuses me lots but im all out of ideas. I'll get the dyno sheet up as soon as I get er done but for now keep shooting off ideas guys. Thanks!!!!!
hey mate i know this may sound way off track but it may help, u say its higher up in the rpm coul dit possibly be the vct on the rb25 not switching over to give it more or less timing ect? im dnt no a great deal about this stuff but am slowly learning and thought that this may be your problem. hope it helps
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
