Log books to confirm low kms?
Records are somewhere in my friends shop.. but they are there.. I bought the car with 76xxx (imported from Japan, apparently the previous owner was some middle aged fellow), rolled it up to 95xxx, mostly highway driving, and with no problems at all..
https://www.sau.com.au/forums/topic/184570-like-wtf-mate/#findComment-3340945
ofcourse! all skylines are owned by middle aged men in japan...
https://www.sau.com.au/forums/topic/184570-like-wtf-mate/#findComment-3341418
...who didn't have the time to drive it and has been kept in a dry, clean garage under a car cover for the past 7 years, explaining the low (genuine!) mileage. Also, the car goes really good for what it is. Possibly a 'freak' engine from the factory
Edited by Yawn
https://www.sau.com.au/forums/topic/184570-like-wtf-mate/#findComment-3341432
...donated to him especially for his services to Nissan Japan over the past 30 years...
https://www.sau.com.au/forums/topic/184570-like-wtf-mate/#findComment-3341459
Yep, and only ever driven once a week to the local Lawson store to pickup the latest copy of Pent Japan.
youre forgetting the customary asahi tallboys, mate :rofl:
... cant...forget...the tallboys. :wacko:
https://www.sau.com.au/forums/topic/184570-like-wtf-mate/#findComment-3341551
The motor had a tuned ecu plus intake/exhaust, that is ALL. No turbo, no boost controller, nothing putting any extra stress on it. I kept up the maintenence. I didnt even drive it hard. I just dont get it. Low kilometer motor thats great one day, dying the next.
/rant.
whoa on second thoughts nick, looks like this particular salary man was in a heck of hurry every week to get his fix...
Op, sometimes, and i mean only sometimes you shouldnt swallow every pill people tell you is good for you...
https://www.sau.com.au/forums/topic/184570-like-wtf-mate/#findComment-3341562
Sounds to me like you had a stuffed injector staying open and dumping fuel (from the stored pressure in your fuel system) into a cylinder. Cylinder fills up (fluids are incompressible remember) and when you try to start it if the piston on the full cylinder is on its way up it hammers f**k out of the gudgeon pin (little end) and "pop goes the RB..." If said cylinder is on its way down, you get lucky and excess fuel gets dropped into the sump.
I had the same thing happen once on a bike, fuel tap was leaking and the carb overflowed into the bore. At knock off time I trotted out to the bike and tried to crank it over and it wouldn't spin. After about 10 goes on the starter it cranked over juuuuuust enough to spit the rod through the side of the bore :)
https://www.sau.com.au/forums/topic/184570-like-wtf-mate/#findComment-3341881
Wow some of you need to grow up. Didnt your mommy's ever tell you, if you dont have anything nice to say DONT SAY ANYTHING AT ALL. Once again, grow the f*** up.
I put the exhaust and intake on, along with the Mine's tuned ecu. It was stock when I got it.
The car pulled like a raped ape, never showed any problems at all, and the chassis of the car definitely did not show much sign of age. I am confident to say, its probably one of the cleanest cars on these boards. Was.
^ Rooster, I think an injector went south in a HURRY as well. Which is kind of sad, as that would mean the motor had just 3000 kms to wreck itself.
Whatever. I gave the car to my friend. He's going to just swap the motor, or stuff in an rb26.. after that it will be gifted to his wife haha.
Edited by 403_r32
https://www.sau.com.au/forums/topic/184570-like-wtf-mate/#findComment-3342619
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
