Jack, who on here is still running just front AP CP5555s? snowflake has rears as far a i know... how do they go at Sandown?
I can't think of anyone that just runs the AP CP5555s on the front, actually STOCKGTR (Nick) on these forums runs AP fronts with standard rears, although he hasn't been on the track for a while, maybe shoot him a PM for his opinion...
Will be good to see your car out on the track!!!!
  • Replies 82
I bought mine through Unique Autosports, was about $8.4k for the whole kit, so 5k for the fronts sounds about right...
Check here: http://www.nismo.com.au/pricelists/pricelist_gtrbrakes.htm
Although the kit comes with Ferodo DS2500 pads for the front, if you ask nicely I'm sure John at UAS will chuck in the Ferodo DS3000's instead....
DS2500 are good for the street, but with your car you'll need the DS3000's....
Noice. Some questions:
Which rotor diameter did you get (365mm?)
What wheel rim diameter are you running?
What sort of piston area are those things running at the front & rear?
Well, personally, i think 355 is on the money. You are better running a ticker rotor then larger diameter rotor. At 355 you can still run 17" rims and tyres. Although if you find you are heating up 17" semis too quickly then that is another reason what you may want to move to 18" rims/tyres.
But as far as braking and handling goes, i would think 355mm x 36 is the ideal rotor size. Next to that 355x32. But 365x32 wotn be any heavier really then the 355x36.
yes but a 355 you may struggle to get under a 17" with good clearance (unless it's a Te37 or similar)
furthermore a 36mm rotor takes longer to get the pads up to temp
Yeah they are 365mm up front.
He runs 18"x 10.5" CE28 on track and 18x10.5" LMGT4 for street....
Not sure about piston area sorry...
I run a 17" rim for track work - I suppose I should look at changing size to 18's to accommodate larger rotors? Thoughts!!
Definetly!!! 17's will not accomodate for 355mm rotors, and if they do there will be fark all clearance between the rim and the caliper.
Also 18's you will be able to go wider aswell, and run atleast a 265 wide tyre = more grip....
Correct, although not sure on what piston diameter the Alcons run..
Roy (the brake expert!!!) reckons they have a larger piston diameter than the AP CP5555 calipers... I don't have concrete evidence...
how about this - you give me your car, i take the calipers off, and measure them.
i give you your car back.
deal?
I don't have AP CP5555's, but i've got Porsche/Brembo 6 pot's on 355x32 rotors with stock rears. I do have Hawk blue pad on the rear, but they are bog stock appart form that (not even slotted rotors).
Edited by sav man
Well ppl are fitting 355mm rotors with the bulky Brembo F50 caliper under a 17" wheel, (GTR offset) so since it is one of the bulkier and more rigid calipers gettign around?!?! Though yes, you are left with stuff all clearance to the inner wheel.
AP CP5555 calipers have the following piston sizes: 27mm x 2 / 31.8mm x 2 / 38.1mm x 2
Alcon Monobloc 6 piston calipers piston sizes : 30.2mm x 2 / 34.9mm x 2 / 41.3mm x 2 (i have also seen a data sheet saying the largest pistons are 38.1mm which makes more sense then the 41.3mm)
So as you can see the Alcons have a lot larger piston area then the APs
Ok, I've got to get in on this because I want to know what you guys think about how all this alters the brake balance front to rear and what you have done about it?
ie, you go put a massive set of brakes on the front, and yes - now they don't fade, you always have brakes etc. All good.
But do guys check your stopping distances before and after? Or is it just not making that much difference..?
Do you have any adjustment to sort this out?
Technically, it should be making your stopping distances longer since the rear brake will be proportionally less effective.. so by the time your fronts are at maximum braking force, your rears are only doing 50% of their potential braking... (numbers for example only ...you get what I mean...)
:domokun:
I told you, he IS THE MASTER!!!!
you freaking brake nerd-alert
Has anyone successfully made a bracket and sourced a rotor to offset the STD brake caliper.
Im looking for a budget upgrade.
there's a japanese kit that offsets the std gtr32 sumitomo to a 324 (around that) Supra JZA-80 rotor...
will have a look around for it - it's in one of the HyperREV GTR publications
There are three parameters for the brakes (Assuming you have no external balancer).
1. Piston size. The larger the piston area in the calliper the greater the bias toward that end.
2. Rotor diameter. The larger the rotor diameter the greater the bias toward that end.
3. Brake pad friction coefficient. The higher the brake pad friction coefficient the greater the bias toward that end.
A new set of brakes SHOULDN'T massively change your stopping distances on a once off basis, unless you are running very sticky tyres that is. What it will do is stop you well time & again.
The frustration I get is that very few of the suppliers will quote you piston areas (or clearances for the rims) & all of them assure you their particular setup will be balanced nicely. So they offer you a larger rotor with a unchanged piston area for the fronts & then tell you the balance will be fine.
So either it doesn't matter or they are full of shit. I haven't made up my mind on that, but I suspect the latter.....
Edited by djr81
1. Piston size. The smaller the piston area in the calliper the greater the bias toward that end.
Is that right? Brake bias is the ratio of brakign torque front to rear. So if you increase the piston diameters at the front then you are increasing the front brakign torque whereby increasing the front bias.
Now pedal travel is a different thing...we are talkign brake bias arent we ???
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
