I an really trying to like the M35, but that arse end is so ugly. If someone was to make adecent rear lights kit, like was done for Commonwhores, I may be tempted. Front and side, AOK, but...........
I have bBenny,s pic as my desktop.
Actually, if you have a decent looking rear muffler and drop the car ~25mm.... the rear can look alright.
If you don't like the Volvo lights, just get a reflector cover kit (Yahoo Auctions/Import Monster) or take the whole light of and paint it yourself.
Here is a 2002 Axis with top reflector covers
And here is the Pond M35 rear... rear bumper and full reflector cover kit.
Nissan made the arse end like that just to keep the cops off my back. Works a treat, even with a 3 inch straight through exhaust.
Just gotta get some Volvo badges for the back and I will be in the clear.
You could always paint the top part of the lights to match the car...
;) .... for now
I've noticed that a lot (possibly all?) M35's have the stereo controls moulded into the centre console set up as opposed to the old swappable DIN system.
I'm assuming the radio frequency range still cuts out too low on the FM band like other imports.
What are the options for replacing the stereo?
What do most people do?
Andrew, if you do not want the integrated setup that you have seen in the ARX, get an RS.
You will be hard pressed to find an RS with all the goodies, but it is the only option without the integrated unit.
RX, ARX and Axis al have the integrated unit and all RS's have the separate Clarion unit with 3 gauge DIN.
I am sure that you can always change the headunit over and connect it up with the integrated unit though.
Edited by iamhe77
OK
Is there a common work-around or fix for the radio in the integrated unit?
OK
V35 FAQ
See what Chris has posted regarding the BOSE unit. I presume it is the same for the standard integrated headunit, but maybe fire him off a PM to make sure what is involved in changing it.
V35 FAQ
Cool. Thanks.
Yes, no, yes.
Upgraded front bar on it's way, as is the bonnet... and I have the lights that you do so love.
I bet you have every thing crossed that it will all line up this time....LOL :)
Edited by andy65b
i know where there is a PM35 we can get the parts from cam :ph34r:
Nah, dark blue is not my colour....
Besides Ben was willing to sell be a PM35 bonnet, but the price was NOT right.
I bet you have every thing crossed that it will all line up this time....LOL :rant:
It will. The bonnet was the only issue.......... :) ...... I hope......
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
