the lead I sell gives RCA input to the stock system. you still need to feed it a NTSC signal but thats it. if you do the camera I need the OEM tv tuner as I need to modify it.
Thanks again Chris. Does this lead fit into the tuner at the rear or piggyback at the main unit in the dash? I would like to purchase one from you anyway. Could you PM me details with p&p to Auckland NZ or would you prefer I contact you at work. What is protocol here? And if possible could you please indicate cost to modify the tuner for a camera, I will look to remove this as soon as time permits.
This all sounds great.....my new happy place :)
I could be wrong but i think what you are referring to is the Attessa reservoir for the AWD system. In my car it is located behind the right-hand side storage compartment. I don't know but is your vehicle rear wheel drive only?
Hopefully that helps.
Cheers
I thought that was what that reservoir was for, and knew where to find it behind the right storage compartment. The strange thing is that my car is 4WD, but doesn't have a reservoir there at all. Could my 4WD system be different? The only thing I can think is that being a later 2006 model, maybe it's shifted to somewhere else? The left side compartment has the TV tuner behind it.
Hi Spong, nice to hear from you, fellow Kiwi and thanks for your response. I had suspected that the ausy system wouldn't work yet but thought it might in the future, I did not know that it is completely different. Typical that we would choose to go down a completely different route. I had thought that a Pal to NTSC converter might be required or that I would just use the tuner as a pass thru to connect other devices. Oh well, I have limited knowledge at this point but time spent here should provide some options. I had also assumed that i could use a modded original xbox outputting NTSC for DVD & games and that this would connect to a tuner as an input.
Anyway, loving the car it is indeed awesome. Were are you at, I'm on the north shore.
Hey neighbour, I'm in Mairangi Bay on the North Shore also. I've been in the electronics and IT business for many years so have an interest in doing something more useful with my screen also. NZ did pick a different digital TV system to most countries, but technically it's better and a few other countries are heading down that path. I think a suitable car option will be here eventually, but it could be a while.
Nice! Yes neighbour indeed, I'm in coastal Beach haven up by Birkenhead. Not far away at all. Good to know that we both intend to go down the same path and will be able to throw ideas around with each other. Although with your background you might have a few more ideas than me :) . I'll keep an eye out on the road, can't be to many blue M35's on the shore, I'm sure we'll meet up one day. Good to hear that there might be a distant solution for incar Tv and I guess we deceided to do it once and do it right, albeit differently. I best add you to my friends list. Catch ya later.
I'm just gonna rip all that shit ourt and also those useless gaugesl and replace nav unit and screen with a decent cuddy and the gauges with a sony 7 inch touch screen (with nav system option maybe). $1500 and the latest and greatest, sorted. Win win.
I've thought about that too and if this all becomes to hard that still maybe the best solution. The only thing is I've got the 6-disc in dash Bose system that does sound good and I'd like to keep that for now...oh well early days yet!
I've got to do a few other things to it first as it's fresh of the boat, transmission service, brake pads & rotor skim & an upper cylinder cleanout with a service.
it plugs into the stock tuner. give me a call at the shop . easier.
that tune will change when the thing breaks.
Yeah, mines fresh off the ship also. I had to get new rotors and pads to pass compliance. They're getting really tough out there now. I'll look at transmission service soon.
One thing our Aussie mates haven't had to deal with their VQ25DET motors but we will with our VQ25DD and VQ30DD direct injection motors, is the build up of carbon in the intake manifolds and possibly combustion chambers. A couple of mechanics have warned me of this, and another Kiwi, "chad bob" has written about this at length here:
http://www.skylinesaustralia.com/forums/Di...29#entry5263429
Looks like I'll get some Subaru upper cylinder cleaner before this becomes a problem.
:) ha ha Yeah, so I've been reading....and maybe experiencing as it has already skipped a couple of times for no apparent reason. As I have just got the car the Dealer has said they will clean the deck. It goes in next week and because it's such a mission they'll have it for a couple of days. At least i get a courtesy car!
Thanks that's interesting. I think I'll grab a can from Subaru in Wairau Rd. Mine has just rolled over 100k and although it feels smooth it could probably benefit from this. Mine was the smoothest of the few I drove, but they probably all could do with it.
I just did a trans service at 168,000 kms. Not sure if it had been done before and car is now 8 years young but old fluid wasn't too discoloured. Mechanic thought things were looking good and only a few metallic bits in the filter. I had been experiencing intermittent steptronic issues that might have a faulty temp sensor as a cause. This is expensive as whole unit has to be replaced. We'll wait and see.
When you do the rotors only do them on the car and clean out all the crud around them. If upgrading brakes you'll only need to do the fronts but you probably will need new rims all round. You can get good ones from wreckers. I got mine from All Nissan in Lwr Hutt and the brakes too, which came off a GT-T skyline.
Hey STAG250 thanks for the heads up. My trans fluid looks good and is the correct level but I bet it hasn't been done in Japan recently so I'll be doing it shortly and good luck with your temp sensor. At this stage I'll skim the rotors and change the pads and see how that is, at the moment it has a shudder. I have a need to tow a bike trailer so we'll see if an upgrade is required later. Mine has factory 17" alloys so I'll be mindful of that if upgrading. I might get this first local service done at Nissan Takapuna
so it can all be checked out but I'm aware of the premium they might charge. I'd normally do standard services myself but might let them give me a good starting point. I'll keep you all informed of costs and parts used as I progress.
I had that shudder bad too and took three goes to get it right. Mostly it comes from the rear I think. The mechanic who sorted it out for me finally, removed rotors and cleaned things up before re-assembling them and skimming in situ. This was after I'd had fronts replaced and rear rotorss skimmed off the car in Welly.
Thanks, I'll get them to follow that for both ends. Would prefer if this was cured in one go!
Hey Blade NZ, Look forward to hearing how you get on at Nissan Takapuna. I've generally used them for anything I won't tackle myself, and find them competent and fair. It's worth signing up at their website www.citynissan.co.nz in the service area, and they'll send you a 10% discount card for service and parts. The service manager there, Warwick Jarvis admitted they hadn't seen many M35 Stageas, and wasn't aware of carbon buildup in Di engines, and that surprised me. I remember when I took my '97 Stagea there back in 2000. They all crowded around it like a new toy.
Spong, how are ya! That's good to hear about takapuna i.e. City Nissan. I was going to ask you whom you recommended locally. I will sign up tonight. I was in there the day after I picked the car up for new wiper blades, first big rain and the wipers were past it. The girl in parts was excellent. She came out to confirm variant, all in stock as a blade only or complete head. I got the complete unit at $23 ea. Part # NB8890U52XB. She then proceeded to fit them....Nice! Had a quick chat to the service guy, all seemed good, workshop looked good and if the price is reasonable they've got my business. Thanks for the assist!
Oh and I picked up a can of that Upper engine cleaner from Winger Subaru today @ $22.50. The guy in parts there was less than helpful and a bit of a dick...must of seen what I drove up in. :happy:
Might have a go at it tomorrow if time & weather permits (and there are no neighbours about) hope it doesn't smoke to much!!
Yeah, please let me know how you get on. Is one can enough for a V6? Where do you insert it - a breather, or just before the throttle butterfly or somewhere else? I wonder if some of that dislodged carbon finds it's way into the oil? Some say you put 1/3 in the crankcase, 1/3 in the gas tank, and 1/3 into the manifold. So many questions. I'm glad you're doing it first :thumbsup:
Yeah, please let me know how you get on. Is one can enough for a V6? Where do you insert it - a breather, or just before the throttle butterfly or somewhere else? I wonder if some of that dislodged carbon finds it's way into the oil? Some say you put 1/3 in the crankcase, 1/3 in the gas tank, and 1/3 into the manifold. So many questions. I'm glad you're doing it first :D
Ha ha, I was looking for that very info. But alas it looks as if I'll be the first. Only had a quick look under the cover today and the only obvious (easiest to get to) vacuum line was at the very front of the manifold. The can is small, only 150g net, and instructions are warm up engine, turn off, remove convenient vacuum hose, spray in half of can, wait 5 min. run engine at rpm to prevent stalling, spray remainder of can in, stop engine as can empties, wait 5 to 10 min. restart engine and rev to purge. Road test.
I think I'll follow this for now using the front vacuum entry and see how it goes. I do wonder about the throttle body though as it's at the other end of the manifold. If there is another vacuum line accessible there I add some as well. As for the petrol tank I think I'll add a bottle of Chevron Techron and the engine will get a quality oil change (Dealer did change oil but I'll bet it was cheap). I'll keep you posted although the weather isn't looking to hot tomorrow :)
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
