I believe the cloth is a more comfortable seat, I just felt like I was perched on top of the leather, instead of nestled in, but that's an individual thing. Don't get too hung up on a detail like that; I think there are more important things to focus on.
Edited by Daleo
Like twin sunroofs!
I notice you're in Adelaide Mr Wombat. I bought one about 2 months ago from Northshore in Sydney, flew over, drove it back. No issue with the ID check and transferring rego (except the stamp duty! $$$$!). Car was exactly as Ben described, and he gave good directions on public transport to get to him, and picked me up from the ferry.
When I looked around, there just weren't enough around in Adelaide to get what I wanted. I would have no hesitation buying from interstate again.
If you want me to take you for a spin in mine, more than happy to, just send me a PM. Just make sure you come to the next Stag cruise!
Yeah sorry bout that, just wondering if they are generally trouble free... I am looking at m35's with less than 50,000kms on them... There are a few c34's here but no m35's so I can't really check them out... Looking at ones in nsw....
lol, talk about a vague question.
Whilst I like Legnums, an M35 Stagea will shit all over the two cars you mentioned.... unless you want to tow something
Legnums that bad? I thought they're a bit faster/better handling out of the factory than the M35's, no?
More thirsty too...LOL...and probably harder to source parts for?
NM35 will be a minimum of 8 years old.
There will not be many with under 50,000kms without being wound back.
They are generally very reliable cars.
Only thing that definitely will die is the turbo.
Any Nissan dealer will get parts in for you, but it is definitely easier if you DIY or have a mechanic/dealer that actually enjoys what they do and will take the time to figure stuff out.
As a point of reference, the only failures I have had have been the turbo, passenger side front wheel bearing assembly and the radiator.
Not bad considering I have just passed 215,000kms and mine is a 2001 build (one of the earliest batches).
Not bad considering I have just passed 215,000kms and mine is a 2001 build (one of the earliest bitches).
FYP
i rekon they are reliable too
mines done a radiator (seal, not cracked) transmission has an issue but its a known fault normally fixed in japan. my dealer was a d1ck. and the turbo is still going strong at 120+k on the clock!
Gt high performance - kirrawee !!!! Anyone had anything to do with them... I haven't talked to them, just looking online at the moment.....
If you're in the Sydney region I've heard nothing but great things about northshore prestige motors. I would definitely start there.
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
