:action-smiley-069: Hey boys and girls
After few months of procrastination I'm the new proud owner of black m35.
This the one from Northshore Prestige with few nismo bits on it already which will save me few $$$.
I can only say that process of buying from Ben was best ever and i can highly recomend them to anyone out there looking for quality car and dealing with decent and educated salesperson like Ben and his crew who always had time and patience and are also very competitive.
Most imoprtantly I've purchased high quality vehicle with extras and I'm loving it. :thumbsup:
This will be nice a adition to my 32 gtr which gets driven on sunny weekends only.
Also I've been reading this section for few days now and you guys are much better in sharing info then skyline forum.
See ya around
Dave
I'm sorry but let me at least change these stock rims to something like matt black 18-19inch (do let me know your thoughts)
Apart from that it's got lowered suspension (nismo)leather interior and little flat spoiler at the rear. :whistling:
Also if anyone is looking for cheap stock rims with new tyres let me know.
Oh yea I will enjoy that it feels so nice smooth but heaps of go when you need it, just great and practical car I cant fault it.
The only thing i need now is spare key, cd english conversion and tv?
Dave :cheers:
Dave :cheers:
and to open up that banjo bolt to the turbo. hopefully save the little bastard
Does this need to be done to the standard turbo? Will it help it live longer?
depends.
Do an oil flush and run good oil with oil changes every 5,000-8,000km's.
Or
Open up the banjo and insure it never get's blocked so oil feed is never an issue!
Ah ok. I always change my oil on turbo cars at 5000km no more. So hopefully all will be good.
Wouldn't there be a restrictor in the turbo oil feed anyway, as all BB cores have.
So opening up the banjo bolt shouldn't make any difference to get more flow/feed.
See ya around
Dave
Good stuff, Dave! Good choice of wheels to keep the GT-R company in the garage.
I guess this falls under general info.
Don't bother trying to do a burnout in your RWD M35. Computer says no.
It will limit revs to about 1500rpm and you will sit there doing absolutely nothing. :domokun:
Before anyone asks why one would bother. Was at the gokart track and it's manditory to do a skid whilst exiting.
you need to find the magic wire to the ECU that's limiting it........then it's bag em up time!
the stock turbo is a bb core isnt it? hence the reason the restrictor being so small as BB cores require less oil?
open it up. even if you are doing the flush, open the banjo, scot was running his at 18-19psi for about 4 months i think and the turbo still came out perfect.
Oh rly?
Someone with computer hacking skills needs to enlighten us on where this magical wire might live. I need to regain some lost manhood here.
Oh rly?
yep was the case wwith us.. me and scotty found the wire.. and 100% throttle on stall appreared.. obviously would be different with your m35 though
was the brake signal wire.. might help but dont hold me responsible lol
Different car sure, but the thing about mass production is making things as similar as possible across the model range is the cheapest approach. I reckon the ECU's will function in the same way. Will search for the thread.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
