I've sent an e-mail or two off. Lets see what the replies are.
A bit OT but have you done a new 0-400 run yet? I'd love to see a wheel mounted camera on the speedo too, you have a laptop mate?
Ask him again when the Fcon is fitted.
He won't have speed cut then lol
Is anyone on here running a 9.5in wide rim on there car? If so what offset would you be running?
Just found out the wheel I want doesn't come in the size of choice... 8.5 +22 only a 9.5 :/
+38 is what you want. But only has about 3mm clearance on the front between rim and suspension upright link.
I went with a 9+30. It's sits out at the front about 3mm and flush at rear. It also gives plenty of clearance on te inside at the front. Just work out what size you can get that sits the same as a 9+30 and all will be sweet.
They don't make anything that will fit I'm afraid. Back to square one.
I know how you feel. I was originally after Work XT7 but couldn't get them in the size needed while still have the concave face. The other face looks ordinary.
The brand i had chosen, Varrstoen, did a good looking wheel with out the cost of a jap rim...
What did you end up going with if you don't mind me asking?
Mike.
I went with Work XSA in a silver face with polished lip in 18x9+30. They are a 2 piece rim with just over 70mm dish in my sizes. They can be ordered in any size and offset you want as they make them to order. But be prepared to wait. Mine will be shipped tomorrow and here in 6-9 weeks plus I waited 6 weeks for them to be made. Price is pretty good for a quality Japanese wheel, around $2200 delivered (on special when I ordered them) from memory, no tyres of course. I'm a bit anal about only using Japanese wheels on Japanese cars, they just seem to fit and finish the cars off better IMO.
Edited by slippylotion
Who did you order through?
Like to see them when they arrive, look nice.
I've got a mate working out with Braid about a set of wheels at the moment, see how that goes otherwise I saw a few nice ones on that Work web site!
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
    • I didn't actually try it at the time but a Launch X431 with the appropriate software licenses/upsell will have the ABS bleed function. The Consult II you can still find some old sets of equipment but they're really, really expensive:
    • Well I'll start by saying I'm not an engineer. I am going to go with the KiwiCNC ones.  They are made of 7050 alloy have good fillets and radius.  The material alone is in the order of double the strength and fatigue resistance - Those bolts, once torqued correctly place most of the load at the flat face of the mating surface - the 'stretch' you're talking about through torqueing them up would be far more than the extra stretch 'load' placed on them from a steering input or bump. (in my opinion) so I doubt they would flinch.    - but again "not an engineer".      oh and I don't think stitch welding 7050 is a good idea, likely just weaken the material (from what I read)
