Sorry, I feel like I've hijacked the forum.
Just one more question, someone raised the possibility of importing.
How is J-Spec as an importer? I know you can't bag out company's on here but there are ways to do that without actually doing it .... or you could pm me.
I have gone thru J-Spec,(soon to land an M35) after being referred by a work collegue who brought 2 cars thru J-spec, and I must say Ben has gone above & beyond, is very helpful and answers all questions if he can, and if he cant, he'll get an answer for you. Top bloke cant recommend him enough. I wouldnt hesitate to buy thru Ben again. J-Spec Imports
Hey people,
I'm having trouble buying two belts for vq25det on M35 in Autobarn as they had no listing at all. :rant:
Does anyone know aftermarket part numbers for these belts?
Thanks a milion.
Dave
Hey people,
Thanks a milion.
Dave
Belts are the same as 350z;
Alternator - 4PK950
Power steering Pump - 6PK1180
Link to belt "how to":thumbsup:
http://www.m35stagea...lit=belts#p1867
Edited by Daleo
yeh they are the same. just keep in mind that the pictures are different to the actual product,
we dont have camber adjustable tops.
which is why i bought the V1's, I couldnt justify spending an extra $300 just for a bees dick larger canister
Yes, that's them. Send Paul at Street to Track an email (I PM'ed you) & ask what the current price is. Mine are on the way (with custom spring rates) & were $1165 delivered.
But if you are in a hurry, Just Jap would probably get them to you sooner if they're in stock & you get standard rates.
Hey Aaron, since when does $1299 - $1149 = $300 (JJ prices)
lol @ your maths. What is it you do again?
Edited by Commsman
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
