You could probably re-direct that comment to those that have said it is relatively quiet (bar the blitz NUR) on this forum.... maybe they're wrong? I disagree with you on looks though ... the standard has two tips and so does the legalis... now when you consider most rival tips looks like cannons then I'd certainly assert it does look close to stock in comparison.
Yeah, when you give it some, the thing is loud. The nismo I have is pretty much the same. It's not near stock. At low revs, it actually does a good job at keeping things kinda quiet.If you really want an exhaust that is stock quiet and flows, then it's going to be custom.
I don't know what I did above ^^^ (how do you delete a post).
I thought (again from what i've read on here) custom exhaust weren't as quiet as some branded exhaust. If not, i'll just do that, they're cheaper as well eh?
Well, all depends on what you say you want. If you ask of a 1.5inch spaghetti mess, they will give it to you.
Ask for a quiet flowing exhaust with stock noise, and it might cost a bit more, but they will make one.
You in Sydney? You can have my 350z mid pipe that flows a heap better for $80. Larger diameter and just a resonator, instead of that massive muffler.
For pic see
Here
Edited by PN-Mad
It's all down to what you ask for and where you take it.
I have a custom AM Performance exhaust. It was a development version, so it was too loud to start with, but it has now been fixed up and is pretty much to my liking. Andrew at AM will sell you an exhaust to whatever volume you'd like. You want a crazy loud one, he will oblige. Quiet? He will oblige.
Mine is reasonably loud when you put the boot in, but doesn't drone on long trips. It also looks sex with twin 3" titanium tiips. Everyone who sees them, loves them. Mmm... titanium...
lol the blitz NuR is quiet.. i got one and you can hardly hear the dam thing.
Mine was like that. Wait a 1000 kms or so & it'll get louder; or more noticeably the note gets deeper.
Relative to what though?
I owned a Legalis for a couple of years up until last year where it went on Scott's car and the Nismo (same as on Alex's PNM35) went on mine.
Regarding looks, I like both of them, but as you can see in my sig, definitely not stock looking.
Custom exhaust depends on the competence of the maker I guess.
I understand a lot of them come over with only one key .... what did you guys do getting another one? just got another cut ?
Invest in a good alarm & 3 point immobiliser, and get some more keys cut. The blank key (with no buttons) has the part number H0564-AU000, search for it on ebay and you'll find some for around $30 delivered; personally I think thats the easiest option :thumbsup:
ive had mine for around 15-20,000 now. still quiet... but i havent got a dump yet...
Hmm this might be a go'er if the Legalis is loud. I know a dump improves performance significantly (and i'm doing that) but does a cat-back in these cars do much on top of the dump?
Any recommendations for an air filter or is a K&N from autobarn or supercheap good enough.
Upon importation, did most of you get it serviced straight up? Compliance don't do anything along those lines do they?
I recommend not getting a pod, but instead using the factory air box, getting a K&N filter or the like, and getting the 'power duct' genuine nissan attachment (part number is somewhere on here)
It's cheaper than a pod and performs just as good if not better and you retain your cold air intake. It also seals to the top of the bonnet too!
I actually got mine serviced after compliance, because the compliance workshop didn't change the fluids. (Idiots)
The key with these things is to change the oil and filter often as per the typical turbo oil replacement schedule.
Luckily with mine the service history was good, so it didn't really need it, but better safe than sorry.
Dump should be number 1 priority, for both performance, economy & increasing turbo life. A cat-back does help significantly & you will see what we mean when you look at the factory mufflers, especially the HUGE one in the middle of the car. Weight saving along is worth the upgrade, lol. After that, the mid (front?) pipe can be changed for one with a hi-flow cat & there will be more (but lesser) gains. If you do this, get an exhaust bung for wideband sensor welded in at the same time.
Stick with any off the shelf filter in the factory airbox as suggested above. IMO if you notice a performance gain just by choosing one filter over another, it's purely placebo.
QFM pads are pretty popular around here. I've got HPX pads and no complaints. They're cheap, you can get them through GSL Rallysport, who are a forum sponsor.
AFAIK V35 coilovers will not fit an ARX. I think the rears are different? Plus you'd dump it. What's wrong with BCs?
Just ring GSL Rallysport - I think I had to wait a WHOLE DAY and Greg knows what fits anyway, you'll pretty much just have to tell him you want pads for a M35 Stagea.
As Cam says, they're 350Z Touring, and that's all over the site if you have a search :google:
Oh and the shocks, BC BRs are not universal. No shocks are. I think the fronts would be fine, rears would be different maybe? If they're your sisters just try fitting them and see!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
