MEH!
My CD player won't eject a CD and i'm getting 'CD Err F0.' I reckon it's just cheaper to sort out a connection to my ipod. Is there an AUX at the back of the player or do I need to buy an adaptor, similar to the V35's.
Oh and I didn't realise VE SS did the 100 in only 5.5secs, dayyamm
There are heaps of threads about "fixing" the CD error, have a search in here or in the V35 section.
For an iPod connection to the OEM head unit, the USA Spec PA15-NIS is what you'd be after for simple plug and play (although you will need to get behind the headunit)
http://usaspec.com/product.php?ProductID=30&forceShowProduct=1
http://usaspec.com/p...ceShowProduct=1
I use that same USA Spec set up. Awesome sound quality and VERY easy to fit and set up. Cost was under $150 delivered from the US. It also has a spare audio input if you want to hook something else to it and also charges the iPhone.
scchwweet, thanks for link.
I ordered mine here. Mine was a tad cheaper as the dollar was higher at the time
http://www.ebay.com.au/itm/USA-SPEC-PA15-NIS-CAR-STEREO-NISSAN-INFINITI-IPOD-AUDIO-ADAPTOR-NEW-/400268286077?pt=LH_DefaultDomain_0&hash=item5d31d9587d#ht_3202wt_1378
Edited by slippylotion
Hi All
Had a strange idling problem with my ARX - I was driving the car for good 2 hours then pulled over
strangely the car idles so low where it feels like its going to die. Any thoughts?
Also, can anyone PM me service details for each KMS ie: 10,000kms service and so fort
Thanks everyone
Cheers!!!!
So that will fit the non bose system? Does an installation manual come with it?
Yep fits the single DIN factory deck. Comes with instructions although its very easy to install. All you need to do is name the playlists on your iPhone with Nissan in them.
I run:
Nissan 1 - artists
Nissan 2 - albums
Nissan 3 - all songs
Nissan 4 - blank
Nissan 5 - blank
Nissan 6 - blank
You can set them how you like but you need to name them 1-6 with Nissan.
Nissan 5 allow direct iPhone control rather than control from the deck. If in 1-3 playlists you can jump song/albums/artist via the 1-6 buttons on the head unit.
Overall its a great unit to connect your iPhone/ipod.
Import monster/ streeter?
On another note, Im looking at wheels at the moment. Im not happy with the flap in the sidewall I currently have on one, especially considering I have a drive to Melbourne coming up. Not replacing tyres on the 17s, rather move to 18s.
Looking at either 350z track 18x8+30 or CE28S 18x8.5+30.
Ive seen pics of the 350z track fitment and it looks good. Ive also seen people with 19x8.5+22 and it looks good. Would i be right in thinking 18x8.5+30 will be a good fit?
Not sure if you remember how mine sit but they are 9+30 and I wouldn't go any lesser than that. I think a 8.5+30 will sit in the guard too far.
I'm running +37 by 8.5 and they don't stick in to far.....you can always run some spacers if you want more track!
No the 8.5 will sit out another 6mm and in another 6mm. To fill the guards I would go either a 9+30 or 8.5+22 or if you want them Out the guard a little go for 9+25. These sizes keep good clearance inside to the suspension arm.
PM me your number and I'll send you a pic of how mine sit, can't upload on here as I accidentally killed my MacBook yesterday ?
Well the 350Z Track wheels look ok, based on the pics Ironpaw has posted:
So if the 8.5 is going to give me another 6mm that sounds fine. I don't need to fill the guards right up, and I don't really want them out the guards.
Just wanted to make sure they'd clear, and try and get an idea of how the 18x8.5+30 would look compared to the 350Z 18x8+30, because I knew there were pics online of the 350Z wheels. Might give the guy a call and try and drop round and test fit on the weekend.
Cheers for the help, PM sent.
All depends on how much low you have.
The moar low, the bigger offset you can tuck in- to a point. If you dropped Ironpaws car 1 inch all round, the wheels would be tucked in and IMO wouldn't look great.
Just type in "wheel offset calculator" into Google, and that will tell you how much it will change by. Stock is 17x7 +45. Go from there. We have seen up to 18x9.5 +30... or maybe even a tougher offset on M35s.
Yep, your car is pretty damn low from memory Ryan! I'd be thinking you'll need 10mm spacers at a minimum to make them look even remotely close to "fitment".
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
