MEH!
My CD player won't eject a CD and i'm getting 'CD Err F0.' I reckon it's just cheaper to sort out a connection to my ipod. Is there an AUX at the back of the player or do I need to buy an adaptor, similar to the V35's.
Oh and I didn't realise VE SS did the 100 in only 5.5secs, dayyamm
There are heaps of threads about "fixing" the CD error, have a search in here or in the V35 section.
For an iPod connection to the OEM head unit, the USA Spec PA15-NIS is what you'd be after for simple plug and play (although you will need to get behind the headunit)
http://usaspec.com/product.php?ProductID=30&forceShowProduct=1
http://usaspec.com/p...ceShowProduct=1
I use that same USA Spec set up. Awesome sound quality and VERY easy to fit and set up. Cost was under $150 delivered from the US. It also has a spare audio input if you want to hook something else to it and also charges the iPhone.
scchwweet, thanks for link.
I ordered mine here. Mine was a tad cheaper as the dollar was higher at the time
http://www.ebay.com.au/itm/USA-SPEC-PA15-NIS-CAR-STEREO-NISSAN-INFINITI-IPOD-AUDIO-ADAPTOR-NEW-/400268286077?pt=LH_DefaultDomain_0&hash=item5d31d9587d#ht_3202wt_1378
Edited by slippylotion
Hi All
Had a strange idling problem with my ARX - I was driving the car for good 2 hours then pulled over
strangely the car idles so low where it feels like its going to die. Any thoughts?
Also, can anyone PM me service details for each KMS ie: 10,000kms service and so fort
Thanks everyone
Cheers!!!!
So that will fit the non bose system? Does an installation manual come with it?
Yep fits the single DIN factory deck. Comes with instructions although its very easy to install. All you need to do is name the playlists on your iPhone with Nissan in them.
I run:
Nissan 1 - artists
Nissan 2 - albums
Nissan 3 - all songs
Nissan 4 - blank
Nissan 5 - blank
Nissan 6 - blank
You can set them how you like but you need to name them 1-6 with Nissan.
Nissan 5 allow direct iPhone control rather than control from the deck. If in 1-3 playlists you can jump song/albums/artist via the 1-6 buttons on the head unit.
Overall its a great unit to connect your iPhone/ipod.
Import monster/ streeter?
On another note, Im looking at wheels at the moment. Im not happy with the flap in the sidewall I currently have on one, especially considering I have a drive to Melbourne coming up. Not replacing tyres on the 17s, rather move to 18s.
Looking at either 350z track 18x8+30 or CE28S 18x8.5+30.
Ive seen pics of the 350z track fitment and it looks good. Ive also seen people with 19x8.5+22 and it looks good. Would i be right in thinking 18x8.5+30 will be a good fit?
Not sure if you remember how mine sit but they are 9+30 and I wouldn't go any lesser than that. I think a 8.5+30 will sit in the guard too far.
I'm running +37 by 8.5 and they don't stick in to far.....you can always run some spacers if you want more track!
No the 8.5 will sit out another 6mm and in another 6mm. To fill the guards I would go either a 9+30 or 8.5+22 or if you want them Out the guard a little go for 9+25. These sizes keep good clearance inside to the suspension arm.
PM me your number and I'll send you a pic of how mine sit, can't upload on here as I accidentally killed my MacBook yesterday ?
Well the 350Z Track wheels look ok, based on the pics Ironpaw has posted:
So if the 8.5 is going to give me another 6mm that sounds fine. I don't need to fill the guards right up, and I don't really want them out the guards.
Just wanted to make sure they'd clear, and try and get an idea of how the 18x8.5+30 would look compared to the 350Z 18x8+30, because I knew there were pics online of the 350Z wheels. Might give the guy a call and try and drop round and test fit on the weekend.
Cheers for the help, PM sent.
All depends on how much low you have.
The moar low, the bigger offset you can tuck in- to a point. If you dropped Ironpaws car 1 inch all round, the wheels would be tucked in and IMO wouldn't look great.
Just type in "wheel offset calculator" into Google, and that will tell you how much it will change by. Stock is 17x7 +45. Go from there. We have seen up to 18x9.5 +30... or maybe even a tougher offset on M35s.
Yep, your car is pretty damn low from memory Ryan! I'd be thinking you'll need 10mm spacers at a minimum to make them look even remotely close to "fitment".
    • I sense an out of control build thread coming up lololol. That 450kW goal will end up being 600 to 700kW LOL.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
