Contact Andy. I'm pretty sure he had one in his old car, but I don't know where the probe was installed.
Thanks Scotty and Leon, will do.
anyone know if a v35/g35 front strut bar will fit m35?
Pretty sure, but you can't fit a strut brace and plenum spacer.
Camber/toe kit is the same. If you do a search you'll find the thread from when we got them a few months back, which lists the ebay link.
I have a set on my desk at work still so if you can wait till Monday I'll get you the SPC part number.
Oh, and Cam will know for sure if the strut brace fits. Which one are you looking at? I've got a Freeway Dolphin one which is pretty good and not too expensive.
yea cool, can wait till monday, thanks!
i'll wait for cam to reply in the mean time
how much u got urs for? link? still contemplating whether to get just the front one or together with the rear one from ox motorsports...
edit: saw ebay US, g35 front strut bar for around $150 delivered, no brand one
Edited by Sydsyd
hi guys,
Doing a plenum spacer today, and the first hose i took off, i managed to break a plastic nipple. Need to know what i have broken though. My mechanical knowledge extends alongside 'knows and f**k all'.
Anyway everything went as planned, except for the 10mm spanner now hiding in the engine bay somewhere and a 10 mm bolt. ( and snapped two bolts through rageing)
So please, if you could tell me what i have broken, a part number to replace it, an aftermarket p/n, or if you have one personally, that would be great!
That's the wrong size Darren - looks close to the 350Z ones, but the Stagea ones are wider. Some of your Kiwi 'bros' have worked out it's a Renault Koleos size, looks like a perfect fit to me.
hey mate check ya pms
Looking at changing the colour of my dash fromthe grey/ beige to black and have managed to source a Black stagea dash. However upon arrival and inspection, its been bogged up to the shit house and isnt useable, so my quest has started all over.
Has any one on here done the switch before and any pointers for me? My NM35 is a 03 model. Will a V35 of the same era, series 1+2 i assume, be a straight swap?
Cheers
Scott
Damn it, they have told me this model fits RVCC26 anyone know this?
Syd, part number is 72265, for 2007 & up Infinity G35.
I've still got two on my desk left over from the group buy that someone hasn't collected. I can see if he wants it still if you want?
cool, lemme know how much
cheers! :yes:
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
