excelent. cos i find on sweeping corners it just frys the rears and the inner front. chopping out tyres real fast. so really if it reduces wheelspin on the track it would pay for itsself in using less tyres :mellow:
yes, correct it does help even up tyre wear
when we are launching from a start line, our car use to most times only spin one front wheel, now its all four in a blaze of glory!! :(
russ
Edited by giant
Is there any real advantage to a carbon LSD like ATS make that justifies the difference in price?
well I think the big advantage is you get to tell people you have a carbon diff. but unless they are going to remove your engine and sump and check you can do that anyway and no one will know the difference.
to be honest I don't think it's really necessary. In theory the carbon disks should have some better properties and perhaps they last longer but in reality I don't know how much better (if at all) they are. I've used a carbon clutch and it was great but i'm not tossing my convential clutch in the bin to get one. Cusco diffs are cheap at around $1000 mark and perform very well.
I thought as much. I had heard carbon clutches need a lot of heat to work well so weren't suited to drag racing. I thought there may be some benefit in that for circuit work but wasn't really sure as I haven't actually heard of anyone using one. Maybe useful for chasing 0.001 seconds a lap when everything else is exhausted but unjustified for everyone else.
I can't really comment on the carbon lsd because I've not used a normal plate front lsd. I've used Kaaz and ATS. The Kaaz rear lsd in the honda is noisy but it's been overtighten. The front ats in the gtr is perfectly quiet after the break in process.
Does your make any noise on reverse Russ and what diff are you using in the rear?
Good thread guys - great info.
I busted my front spider gears at the recent Dutton VIC on a launch and turn incident on the long wang @ DECA, so i've got a Nismo 1.5 way front LSD going in this week. The Nismo was slightly better priced than the others and came with gaskets / bearings too where the others didn't seem to.
The Z-tune has the 1.5 way, so I thought it would be ok. I guess i'll be able to give a progress report soon, but.....
I'm told that the ATS 1.5 way front diff was apparently a case of rip the steering wheel from your hand when mounting ripple strips etc, so what we actually intend to do is soften off the 1.5 way Nismo, so that it reacts more like a 1 way. Anyway my thinking was more aimed at replacing the sucker as to increase the strenght over a stock unit, because missing out on 9 events while driving back to melbourne and back again wasn't all that fun.
I'll report back what I think of it on the track when the car comes back.
  • 4 months later...
Be careful when jacking car up to fit front tyres that you dont tighten the wheel nuts up while car is in the air. Locks the front diff up and can result in a car spearing left on 1st launch, and a very dirty racesuit.
  • 3 years later...
    • Yeah i found that alot of parts can be wrong or "very" hard to get the real right one. I already bought some brakes years ago on me "old" GT calipers and they were wrong too 😄  I told them too. Even send them pictures...but they said "EBC catalogue has them on my car... So i dont know what their answer will be. I call monday them and let them know that they are really not on my car. If they were they would be already on a car...
    • Welcome to Skyline ownership. Yes, it is entirely possible parts websites get things wrong. There's a whole world of inaccuracies out there when it comes to R34 stuff (and probably 33 and 32). Lots of things that are 'just bolt on, entirely interchangable' aren't. Even between S1 and S2 R34's. Yes they have a GTT item supposedly being 296mm. This is incorrect. I would call whoever you got them from and return them and let them know the GTT actually uses 310mm rotors. Depending on where you got them from your experience and success will obviously vary.
    • Hi...a bit a "development" on the brakes. I spoke to the guys where i get brakes from...and they are saying that 296mm EBC are for R34 GT-T. I then went to their site: https://www.ebcbrakes.com/vehicle/uk-row/NISSAN/Skyline (R34)/ and search for my car(R34 GT 1998 - it has GTT brakes) and it show me this USR1229 number and they are rly 296mm rotors... So now iam rly confused... The rotors i have now on the car are 310mm asi shown... So where is the problem? Does the whole EBC got it wrong or my calipers are just...idk know what?
    • Oh What the hell, I used to get a "are you sure you want to reply, this thread is XX months old" message. Maybe a software update remove that. My bad.
    • This is a recipe for disaster* Note: Disaster is relative. The thing that often gets lost in threads like this is what is considered acceptable poke and compromise between what one person considers 'good' looks and what someone else does. The quoted specs would sit absurdly outside the guards with the spacers mentioned and need  REALLY thin tyres and a LOT of camber AND rolling the guards to fit. Some people love this. Some people consider this a ruined car. One thing is for certain though, rolling the guards is pretty much mandatory for any 'good' fitment (of either variety). It is often the difference between any fitment remotely close to the guards. "Not to mention the rears were like a mm from hitting the coilovers." I have a question though - This spec is VERY close to what I was planning to buy relative to the inboard suspension - I have an offset measuring tool on the way to confirm it. When you say "like a mm" do you mean literally 1mm? Or 2mm? Cause that's enough clearance for me in the rear :p I actually found the more limiting factor ISNT the coilover but the actual suspension arms. Did you take a look at how close those were?
