Hey guys, just pm me your email address if you want full sized originals... Make sure you can recieve 5mb files tho as each photo is over 4mb...
I have not photoshopped them for corrections, they are straight from the camera and resized...
The original images are 4368x2912 in res and are rather large so I have cropped them down to 800x533 for this thread to keep it smallish...
https://www.sau.com.au/forums/topic/186206-coffee-night-photos-22907/
yea thanks col those fotos are pretty mad.sorry i didnt get to introduce myself properly.do u think you could do somting with the foto of the front of my car with the licence plate like u did with others?would be a mad foto to send back home to the rellys
ps id love the bigger res copies too, can u email them?
someone needs to ease up on the zoom blur effect.
I like it, its hard to be creative in a fluro lite carpark with uneven lighting...
But everyone seemed to like it...
i like the effects!! did u happen to get ne fotos of the arse of my car col or is ^ that all u got? nobody will see my unique rear lights :mellow:
Arhhhhh, only the two posted above sorry...
Number 8 and number 18...
To do the bluring effect we will have to do it again some time, as it was not done through photoshop and im not all that good/fast with photoshop...
But yeah just pm me your email address and ill send you the higher res images, make sure your account can handle a few mb's tho :(
nice pics col :mellow: .. looking good as usuall .. now whos leg do i want to hump damo or tiff lol tiff ur car looks hot GO YELLOW !.. nice transformation .. sorry was late couldnt catch up
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
