Hi guys,
Obviously there are quite a few guys on here making that kind of power....so i was just wondering how much petrol do you use? I plan on getting my car tuned and want to make around 300-330rwkw's but kos its my everyday car i just want to know roughly how many k's im gonna be getting out of my tank....
And i may as well ask at the same time if you guys think i should be able to achieve my target with the following mods....
- Rebuilt engine (forged internals, etc)
- Garrett GT2860r -5's
- Trust cams 264" 9.1mm lift (not yet installed)
- Adjustable cam gears (not yet installed)
- 550cc injectors (not yet installed)
- Z32 AFM's (not yet installed)
- X-Force dump/front pipes
- 3.5" Kakimoto exhaust
- Power FC (still need to get)
- Turbosmart eBoost2 (still need to get)
So im hoping with this set up ill be able to get 300-330rwkw with about 18-20psi.....
Cheers guys!
i dont see why you cant get 400k's to tank with 500rwkw
its how you drive it on the street, if you load it up, its going to use fuel, simple really?
if you drive normal, it won't waste fuel.
this asumes you dont have stupidly large 2300cc injectors and your ecu supports 02 closed feedback and the cruise afr's have been tuned
haha....yeh nah not too concerned about fuel economy, just seeing roughly what i was getting myself in for...i do roughly 450k's a week so if im using almost 2 tanks a week just to get to work then im looking at bout $150-160 in petrol...haha, GOOD TIMES!
yeh i've read a few of those threads, so ill hopefully get it....but i've had pretty sh#t luck with the car so i wont be surprised if i only get 270-280rwkw... :(
you should be able to do 450k's on a single tank
i suggest you review
how you drive (get your gf or mum to drive the car for a week, i bet they can do 450k's to a tank)
your 02 sensor (they need to be replaced peridocially, if youve never done it, change it)
your ecu & tune (cruise afrs make all the difference & make sure 02 feedback is on/supported)
  • 3 weeks later...
i dont think you will have any problems getting into the 300rwkw mark. Petrol becomes an issue when making that sort of power. im a tad over 300 in my 33 gtst and getting around 200-250kms to a full tank.
jesus thats bad im making 380-400 a tank and im above 330rwkws....
rwkw doesnt have much correlation to fuel economy unless you are like 2000cc or insanely large injectors
its how you drive and how you yank the throttle cable and how well its tuned
there should be no reason you cant get 450ks to tank with 300rwkw
^ exactly on the highway ie last trip from adelaide to melb the R32 GTR (350rwkw 700cc injectors tomei pump PFC) averaged 650kms.... around town expect 450-500 depending on right foot. Stay away from fuel pressure regs and spend the extra on a decent pump.
how much fuel you use more depends on how much time you spend on boost. the more time spent on boost the more fuel you will use. also what sort of driving you do also makes a difference. the term city driving doesn't mean much these days. i drove from albany creek in brissy to mt gravatt and only had to stop about 3 times in 45 mins. that trip would've used a lot less fuel than if i had done it in the worst possible peak hour traffic. if you sit dead stopped in traffic for 20 mins a day (10 mins on the way to work, 10 mins on the way home) you will be wasting a fair bit of fuel every week.
Yeah mainly to do with your driving, assuming you have a good tune.
But on a car fitted with a big turbo, you tend to put your foot down more off boost, which is most of the time if your car is really laggy. Compared to a responsive stock car, where you just have to curl your right toe to get moving.
Edited by Yawn
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
