I have searched but couldn't really come up with much info except the Motul seems to be really good.
However, one workshop reccomends the AP Racing even though it has lower boiling temps than the Motul because APPARENTLY, the Motul's can overheat easily, especially after a few hard laps on track.
Also, just wondering if they give good pedal feel ie. firm feel when braking.
Thanks in advance.
I used to pay $$11ty for the Castrol SRF and after a while I got over paying that much so I tried the Motul RBF600.
I can't say I have noticed any difference between the 2 and can't fault the RBF600 at all. I really don't see why people would pay more for a brake fluid when that stuff does the job perfectly.
I've used both AP 600 and Motul 600, both are good and never found a problem with sprint races upto 15laps in 1200kg GTSt or 1550kg GTR.
AP is $55 locally and Motul is $25... I now only use Motul for obvious reasons!
If you want the Motul fluid the best places to go looking are the motorbike shops. For some reason they carry Motul gear.
Also it is dot 4 (600) Which means it is much better than the run of the mill dot 4 fluid. The 600 is its boiling point in degrees fahrenheit.
Stuff paying $55 for 500ml.
Someone will be along in a minute to tell you about the Penzoil gear.
Edited by djr81
In Australia Motul has primarily been a bike brand... only in the last 5-6 years has it been pushed to cars.
Link International used to sponsor my Skyline when they were promoting the expansion.
Its always been big in Europe for both cars and bikes though.
yes, pretty funny. have a look at the bottle. ap,motul,penrite. sanme bottle. just differant lable and colour. all the same in my book. srf is just spastic expencive. we noticed no differance in the utes. (tested back to back)
we melt pistons in the calipers before it boils the penrite stuff.
motul rbf 600 is a DOT 4 only fully synthitic
motul DOT 5.1 is dot 5.1
im useing the dot 5.1 in the r31 and useing it at track days and it good
Why would you use the 5.1?
Brake Fluid..............Dry Boiling Point................Wet Boiling Point
Motul RBF 600..................593°F...............................420°F
Motul DOT 5.1..................509°F...............................365°F
Edited by djr81
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
