Thanks guys. I've found a complete set of GTR Bembos, front and rear. Just gonna price up new Brembo 2-piece rotors/lines/pads. Will let you know what i decide. G4's are good value, just spoke to the boys down there but Steve wasn't there for me to lean on........ (see my sig) :P
  • Replies 369
Yeah, end of Day 1 2005 there was one sitting 13th outright. :P
GTS-t is one of the most forgiving, easy to drive fast cars you will ever sit in... I regret letting minego to that useless Rocket - just as the rules came round to suit them even more.
and to rub salt into the wound, he took a snap of us this year with the old girl in the back ground!
Not sure you will run with the RSR in the dry, but you'll hose him in the wet.
Anyhow, I'm all emmotional now...
Winton, what are you doing down there... I thought you were a Queenslander?
TT
984
What happened after day 1? :dry:
Who ended up with yours? Rocket? Do I know him?
The car is still in Melb so figured we'd drag her up to Winton for a test and flog :P
What happened after day 1? :)
The car is still in Melb so figured we'd drag her up to Winton for a test and flog :)
The 800 camera car is Gregs old car.
130i too heavy, 135i too pricey, Focus XR5T and RX8 too slow. I like the idea of DSG R32 Golf, but suspect a weight issue.
72k for a 135i coupe Stu....... whadya reckon? I'd be all over one like a rash! - if I was that way inclined :thumbsup:
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
