Thanks guys. I've found a complete set of GTR Bembos, front and rear. Just gonna price up new Brembo 2-piece rotors/lines/pads. Will let you know what i decide. G4's are good value, just spoke to the boys down there but Steve wasn't there for me to lean on........ (see my sig) :P
  • Replies 369
Yeah, end of Day 1 2005 there was one sitting 13th outright. :P
GTS-t is one of the most forgiving, easy to drive fast cars you will ever sit in... I regret letting minego to that useless Rocket - just as the rules came round to suit them even more.
and to rub salt into the wound, he took a snap of us this year with the old girl in the back ground!
Not sure you will run with the RSR in the dry, but you'll hose him in the wet.
Anyhow, I'm all emmotional now...
Winton, what are you doing down there... I thought you were a Queenslander?
TT
984
What happened after day 1? :dry:
Who ended up with yours? Rocket? Do I know him?
The car is still in Melb so figured we'd drag her up to Winton for a test and flog :P
What happened after day 1? :)
The car is still in Melb so figured we'd drag her up to Winton for a test and flog :)
The 800 camera car is Gregs old car.
130i too heavy, 135i too pricey, Focus XR5T and RX8 too slow. I like the idea of DSG R32 Golf, but suspect a weight issue.
72k for a 135i coupe Stu....... whadya reckon? I'd be all over one like a rash! - if I was that way inclined :thumbsup:
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
