  • Replies 705
Posted Images
hey paul are you up and racing again??
yeah got a meet at WSID on the 16th Dec. best so far is 9.97 @ 139 MPH last 10 runs have all been within a 10th of a second. 60' best is a crazy 1.41.
but id trade everything ive done for a sub 1min at Tsukuba in a heartbeat.
Oh my god, that's f**kin TUFF! :) excellent driving... your downshifts are awesome to watch... what sort of gearset does the car have?
it's a ppg gearbox, and mark's bloody good at the changes, really shits me :ermm:
here is a vid of the pre race day when we were having bad handling issues, watch the end mark has a huge moment at about 180kays! hehe
russ
pics to follow
Edited by giant
1.41 is crazy, constant nine's is killer mate hats off to you, good to hear your still racing.
good luck on the 16th too!
As others have said, great effort. In my eyes the most impressive thing is the amount of work/time/effort you have put into the car getting it to where it is...Great to see some support by the likes of Hi-Octane etc...but the work you peboth personally put into the car!..not simply buying an uber built car. So envious that you guys have got to go through the build process yourselves. ;)
Top work and cant wait to see what happens to the other GTRs in the stable.
PS...if you ever tire of track stuff i will swap you my POS GTSt which is perfect for throwing sideways into tyre barriers for any of the GTRs :)
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
