the new fuel system for the r33, extra sx fuel pump was required , as one would have been pas the limit!! getting there should be on the dyno soon ! couple of weeks.
dry sump resevoir still to go in back there this weekend with its oil lines.
Edited by giant
  • Replies 705
Posted Images
good to see its nothing over the top.
but, is that a standard battery?
haha no , it's just a sticker, its a special standard battery!!
the car has been sitting for so long i'm not sticking anything else in it until it's up and running again. it's been nearly two years i think!! :D
Sounds like my kind of place!
lol thats cool
Didnt you have a 5 series though?
Never had a 5 series... I'm not *that* old yet :blink:
Don't worry, the silly beemer will be left at home. I got something else to come out and play with :D
the r33 was going to be circuit only but have never had time to finish it off! so trying to finish it now and get it on the track and sell it. it will be a good car it has had alot of money spenton it and hardly turned a wheel it was 80 percent built before we got it.
yeah too many gtr's want to get back to just two!! one each (not that you can ever have too many but the wife does get cranky) :D
the engine bay as it stands tonight, still a bit to go,, trying to make room up the front for the dry sump pump, which means repositioning the thermo fans and a few other bits and pieces.
What do you use the R33 for Russ?
Or what do you intend to build it up for?
Seems you have a GTR for every situation. "Collect the whole set' eh?
didnt you have an evo? have ya still got it?
1. I don't have a mullet.
2. You're thinking too hard. It's a little more obvious than that... We're on SAU after-all :D
Total = 5.8L TT
M3 = 3.2L
Difference = ?
hehe! it will be good to see either way!
It's nothing special, just an R32 track bitch that I'll have fun with and spend way too much money on :blink:
Congrats on your results in Tsukuba btw... Definitely did Australia proud :D
Can't wait to see your beast in the flesh... Those YouTube videos are like teaser porn. All the action, but no money shot :cool:
2. You're thinking too hard. It's a little more obvious than that... We're on SAU after-all :blink:
Total = 5.8L TT
M3 = 3.2L
Difference = ?
Yeah i know it would be obvious
Have you got pics of it? :D
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
