just back from the tuners its like a new car just got a gt3076r installed running 16psi on low boost setting and 21psi on high boost settings. any one tell me what this dyno sheet is telling me. looks like at the top end its letting go. could this be cams?
i have all the supporting mods.
cheers
https://www.sau.com.au/forums/topic/187275-just-got-r33-from-tuners/
PS, i have no idea how or why Cams would give you jumpy power like that.
I really doubt that's what it is, and the power level (250) isn't anything that Cams would have a problem with.
I guess what i'm saying is that Cams could handle 2000rwkws as long as the engine and turbo were up to it.
The only reason you would change Cams is to improve power gains across the rev range etc....
Nothing wrong with standard though if you're punching more air in.
Two distinct dips but not shaky looking graph line.
I'd suspect 1-2 degrees of timing taken out to address knock. A look at your ignition map will soon tell. :)
The over 4000rpm results looks good, but what do you think about things under that engine speed? Looks a bit lazy to come on for you. This spec should be generally similar to The Mafia, and he's pulling 300kW out of 18psi + a much more linear looking curve throughout the range with the assistance of water/meth.
Edited by Dale FZ1
I'd suspect 1-2 degrees of timing taken out to address knock. A look at your ignition map will soon tell. :P
whats your timing degrees tuned at? if you take out 1 - 2 degrees timing, you will get slightly better mid range power but less peak power..
Previous posts by Murat, and the comment about "all supporting mods" indicates he has a PFC.
I'm suggesting it's in the spark mapping ie adjusting one or two specific cells in the map, not the base timing being adjusted by a degree or two :)
Could be wrong but that's where I'd look if there is a concern/query about the shape of the graph
Edited by Dale FZ1
Explain to me how removing timing is going to improve his midrange???
Id really like to know!
It looks like the exhaust housing may be to small If its not retard to much in the topend.
What sort of timing is it running through the top?? and like others have suggested what exhaust housing are you using??
core number is 700382-5012
compressor housing is .60A/R
turbine housing is .82A/R internal wastegate
if that helps is there any one i can take the car too give me a hand with the problem?
money is no problem.
dude, thats the same turbo as me. (GT3037) I make 15psi by 3900rpm in second gear.
The bigger rear must give it a bit more lag hey?
Also, can you list your supporting mods?
I make just over 300rwkw at 18psi on this turbo.
Engine management - PFC
Boost ran - 18psi
Turbo - Garrett GT3076r
Nismo 740cc injectors
Bosch 040 pump
Gready EBC Profec II
Z32 80mm Air Flow Meter
Hybrid Intercooler
3inch Exhaust turbo back
Splitfire Coil Packs
Stock Internals
no head work
Fuel pump
its not that bad i get about 15psi by 3800rpm its depends on the engine load at the time 5th gear its full boost by 3500
thats strange, as I have almost the same setup, but with a smaller turbo rear.
That wavey line looks dodgey. Are the AFR's staying safe while it is doing that? Is the fuel pump healthy? You'll need to test your pressures.
AFR are safe its is running rich because after about an hour of driving the back bumper has a light black color, fuel pump was installed about 3 months ago brand new, what i will check is the cat see if it is choking and do a pressure test, i know i should be getting abit more becuase i have read your 300kw advantage this is what i have built my car from. so im abit shocked.
anything else you reckon i can check out ?
i have notice one more thing with the car the idle is very high sits at about 900 to 1000 rpm, i tried to reset it to a lower figure but it still sits up at 900 to 1000 rpm could this be a connected problem?
    • After @Kinkstaah debacle, I'd never want to try and get it right 😛
    • The hood lines up with the fenders. The front bar doesn't perfectly line up with the fenders where the wheel arch is. You have to 'squeeze' the front bar 'in' as it wants to naturally flare out and be longer on the sides. There's a few threads where people notice this when they only swap a GTR style bumper and front bar. Unless you have genuine OEM items - you may be better served getting conversion kits. There are GTT bumpers to fit GTR hoods. There are GTR hoods (non genuine) to fit the GTT bracketry. MAY
    • The real question is, on some of those wild roads they call highways, how many times did a farmer in an old ute from the early 2000s blaze past you over double lines?   Tassie is a wild and really cool place, and after doing a work related road trip there January of 24, I understand why Targa Tasmania is ran there, and is so tough to do well at! We had a brand new Camry Hybrid that handled quite nicely, and thankfully weren't in an old car, because cresting some of those hills in a 100kmh zone for it to suddenly be like "surprise f**kers, this is a recommended 30kmh hard right turn" wouldn't be pretty. We weren't racing the Camry around, but we weren't slouching in the bends either. But my lord those old farmers know their old clapped out utes, and those roads, as they were absolutely hammering it!   You're also super lucky to make it up to Mt Wellingtong this time of year. It's often road closed with snow/ice! Also, I hope you hit up Salamander Road in Hobart for some insanely good food (I highly recommend the dimly lit Irish pub for a Guiness Pie, or even the bangers and mash!!!)   How long did the Ferry take to get across? I want to do a road trip of Tas on my own time, but I get horrifically sea sick, and I don't want me on the Ferry, just the car 😛
    • So far so good, about 30km on it so far and nothing out of sorts yet thankfully
    • Look at @Kinkstaah's thread on the issue.
