just back from the tuners its like a new car just got a gt3076r installed running 16psi on low boost setting and 21psi on high boost settings. any one tell me what this dyno sheet is telling me. looks like at the top end its letting go. could this be cams?
i have all the supporting mods.
cheers
https://www.sau.com.au/forums/topic/187275-just-got-r33-from-tuners/
PS, i have no idea how or why Cams would give you jumpy power like that.
I really doubt that's what it is, and the power level (250) isn't anything that Cams would have a problem with.
I guess what i'm saying is that Cams could handle 2000rwkws as long as the engine and turbo were up to it.
The only reason you would change Cams is to improve power gains across the rev range etc....
Nothing wrong with standard though if you're punching more air in.
Two distinct dips but not shaky looking graph line.
I'd suspect 1-2 degrees of timing taken out to address knock. A look at your ignition map will soon tell. :)
The over 4000rpm results looks good, but what do you think about things under that engine speed? Looks a bit lazy to come on for you. This spec should be generally similar to The Mafia, and he's pulling 300kW out of 18psi + a much more linear looking curve throughout the range with the assistance of water/meth.
Edited by Dale FZ1
I'd suspect 1-2 degrees of timing taken out to address knock. A look at your ignition map will soon tell. :P
whats your timing degrees tuned at? if you take out 1 - 2 degrees timing, you will get slightly better mid range power but less peak power..
Previous posts by Murat, and the comment about "all supporting mods" indicates he has a PFC.
I'm suggesting it's in the spark mapping ie adjusting one or two specific cells in the map, not the base timing being adjusted by a degree or two :)
Could be wrong but that's where I'd look if there is a concern/query about the shape of the graph
Edited by Dale FZ1
Explain to me how removing timing is going to improve his midrange???
Id really like to know!
It looks like the exhaust housing may be to small If its not retard to much in the topend.
What sort of timing is it running through the top?? and like others have suggested what exhaust housing are you using??
core number is 700382-5012
compressor housing is .60A/R
turbine housing is .82A/R internal wastegate
if that helps is there any one i can take the car too give me a hand with the problem?
money is no problem.
dude, thats the same turbo as me. (GT3037) I make 15psi by 3900rpm in second gear.
The bigger rear must give it a bit more lag hey?
Also, can you list your supporting mods?
I make just over 300rwkw at 18psi on this turbo.
Engine management - PFC
Boost ran - 18psi
Turbo - Garrett GT3076r
Nismo 740cc injectors
Bosch 040 pump
Gready EBC Profec II
Z32 80mm Air Flow Meter
Hybrid Intercooler
3inch Exhaust turbo back
Splitfire Coil Packs
Stock Internals
no head work
Fuel pump
its not that bad i get about 15psi by 3800rpm its depends on the engine load at the time 5th gear its full boost by 3500
thats strange, as I have almost the same setup, but with a smaller turbo rear.
That wavey line looks dodgey. Are the AFR's staying safe while it is doing that? Is the fuel pump healthy? You'll need to test your pressures.
AFR are safe its is running rich because after about an hour of driving the back bumper has a light black color, fuel pump was installed about 3 months ago brand new, what i will check is the cat see if it is choking and do a pressure test, i know i should be getting abit more becuase i have read your 300kw advantage this is what i have built my car from. so im abit shocked.
anything else you reckon i can check out ?
i have notice one more thing with the car the idle is very high sits at about 900 to 1000 rpm, i tried to reset it to a lower figure but it still sits up at 900 to 1000 rpm could this be a connected problem?
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
