Hi Guys,
Iv got a r34 making around 250Kw @ the wheels.
My exhaust is 3 inch turbo back, HKS dump, HKS front pipe, jjr cat, Trust PE 2.
Would the jjr cat be ok for this application. Has anyone had a problem with a jjr cat?
Its the only chinese part on my exhaust and i was wondering if i should upgrade it.
Cheers :whoops:
https://www.sau.com.au/forums/topic/187665-cat-converter-flow/
Hi Guys,
Cheers :whoops:
do they quote CFM or flow? that will answer ur question, if ur stressed take it off and de-cat...get some flames.
They say they tested it to 570 cfm.
some brands quote some big numbers, saw some tests ages ago somewhere...most we're not as high as they quote. CATCO or Metal Cat were pretty good from memorym Metal Cat are pretty much the premium..
Assuming they are full of shit (better than 75% chance) and 570 isnt a huge number in the scale, you could do better,
Hi Guys,
Cheers :down:
I think you will find they are X-Force Cats, not JJR that Just Jap offers with the 570cfm rating.
i think you will find not much (if any) difference between any cat on the market
unless your cat is actually blocked or stuffed in some way then changing form one type of cat to anther will do absolutely nothing
..you may go slightly faster because the car is lighter from the loss of money in your wallet, that's about all..
I actually went from an X-force cat to a metalcat and i got a fair power increase at the same boost level after a tune...202rwkw to 211rwkw...its all because my tuner was able to dial in about 4 more degrees of ignition timing with the better flowing metalcat...if its bothering you just upgrade it...it won't be a downgrade anyway....
fine, but 100% of the upgrade came into the tuning of the car
i'm sure you could have dialled more timing into the original system and still have seen a power increase
that, and 10rwkw can be accountered for between days and intake temps.
i'm not convinced.
i had a similar experience. went from an xforce ceramic high flow cat to a stainless internal highER flowing cat.
my tuner also said he got more power coz of less restriction. there was an immediately noticeable midrange gain when driving it right after the tune.
if you ask me, it makes a substantial difference.
Edited by Munkyb0y
dyno graphs?
the flux capacitor i installed in my V35 made heaps more midrange but you'll have to take my word for it
dyno numbers, temps, settings etc aside...
get my point? thats not something you can fudge on the dyno
Edited by Munkyb0y
Here is the dyno graph as proof...final power was alittle more because boost was turned up even more after the initial 211rwkw run...
Now...fair enough the concrete visible power gain came from the tune...but i did immediately notice a gain in midrange after the new cat...and that was with a large resonator put in at the same time...as for being able to dial in more timing...well...thats the thing...we couldn't...it would just start detonating...we were scratching our heads on this one for awhile...and i bit the bullet and changed the cat as i was suspicious of it all along...anyway...take what you will from this...i'm just saying that its not that inconceivable...and i know i'm convinced...
you've admitted that
a) you've upped the boost
b) you've had a tune
i appreciate that you have the graphs and at the end of hte day if your old cat didn;t enable to you tune it properly then its fair enough
and as i said in post #7 "unless your cat is actually blocked or stuffed in some way" which is clearly what yours was if it was causing the car to detonate
but i strongly believe for someone with a working cat of any brand, changing to a different one isn't going to do squat. obviously changing from a 1" cat to a 4" cat is going to but that's not what we're arguing here. we're arguing same diameter cats but one of a different brand with a slightly higher cfm rating..
yet to see solid proof in my 4 years having a skyline and browsing the forums
i went from a 3" GUTTED cat to a 3" x-force and noticed NO difference in power whatsoever.
Edited by WazR32GTSt
MetalCAT brand cats are only good for about 100kms though aren't they? I've seen 5 of them delaminate from the internals with a minor misfire on the dyno.
Magnaflow metal substrate all the way!!!!
I'm with Warrren, going from a 3" highflow ceramic to 3" highflow metal did didly on the squat meter...didn't notice a thing.
I see where you're coming from too mate...the thing about my Xforce cat is...the guy who took it off asked me why i was changing it because it was in perfect nick and apparently a "high flowing" item as well...even without a retune i immediately noticed a increase in midrange and the car came on boost so much quicker...so in my case...even though the old cat was in perfect nick...the metalcat still made a noticeable difference...i personally wish i didn't have to spend almost $400 for the metalcat but at least it was worth it in my case...
lol, limpus i swear i'm not copying you. but i had the same experience. when i put the xforce ceramic on, my car actually felt laggier, less responsive, and developed a crazy drone around 2k rpm. i took it off, went back to the old one. then replaced that with a stainless internal highflow, and bam, better response, better everything. thats my personal experience, not my opinion.
Glad to know at least a few other people have had similar experiences...the difference to me was noticeable even though i had a slightly restrictive resonator put on at the same time...not to say the Xforce cats are bad...but when chasing bigger power it makes sense to get the highest flowing item on there...then again...we could always decat the thing but thats illegal so i won't suggest it...lolz...
Edited by limpus
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
