How exactly is the grunt the problem? Are you sure its not just crap drivers and poorly set up cars?
George isn't that bad of a slider and Im sure the setup of the car has had more work than yours or mine
why is the sr20 most suited motor for drifting ? = torquey midrange good "ark up'd ness" abiltiy when capped at power levels under 300rwkw
(lol i.e the way it ramps up onto boost hard)
check out Trent's SR20 for sale thread speaking about Cat's rb26 you'll see that linear power delivery and lots of downlow torque do not automatically make a D1 car
if slamming a ls1 into a shell made a awesome drift car everyone would be doing it hell the Japanese already would have already been doing it
balance and speed make a good skidder
ps can anyone point me in the direction of some credable ls1 engine and box weight specs?
  • Replies 812
I figured as much funny how ls1's wicked cause its lighter than a rb but when you take the box into account I doubt there's much if any difference between the two engine and gearbox packages
sites Ive found quoting around 200kg for a ls1 complete minus box
err box who knows?
anyway goodluck with it just don't expect it to own all first time out
Edited by 1400r
Box is out so ill weigh it tomorro. PS Whats a R33 5 speed weigh?
I cant remember saying i was building a drift car, the car was originally going to be a drag car, i said i would like to drift in it, as well as do some circuit work
and some skids and drags etc. But in saying that i have been carefull in how the engine was mounted, getting it as low and rearward as posible without sump mods, and have had some help from the Sureflow drift team on basic suspension setup for the amatuer, seeind thats what i am. not looking to win any trophies, just have some fun. I have a go kart 4 winning trophies. Believe it or not, the Japanese are not the be all and end all of motorsport.
Anyway, this is the project i have commited too and the engine is now at the machine shop.
Piston to valve clearance was 65thou with no head gasket, so arount 105thou. this gives us the oportunity to deck around twentyfive thou off to bring the comp up so the small cube V8 will develope more low down torque. Piston to bore clearance was a little excessive at 3 thou but good enough for a race car. Just waiting for a hone then ill slap it together. need all i can find to compete with these SR20s.
Edited by BezerkR32
  • 1 month later...
no, only a custom crossmember to suit the box, it is tight though. about 15mm around the top. even the shifter hole is very close. just have to extend it rearwould 20mm.
Car is at my brother in laws getting some minor fab work. mounting the seat, window net, a second side intrusion bar on the drivers side etc. should be finished in a couple of days. The bottom end of the engine is also ready to go, still waiting for the heads though. booked in to get wired in a couple of weeks. clutch should arrive this week.
just from looking at the pics the enigine seems to sit lower than the RB?
also nice work, i would be very interesting in doing this when my little RB goes bang. so there was no changes to the trans tunnel?
i believe the ls1 motor is 50 kilos lighter that the rb... have a dvd at home where there is a twin turbo ls1 in a 34... they call the thing Frankenstein's drifter. it also has the tremec box.... although these days the car actually has a stroked 6.6 litre ls2 with a masive twin turbo set up... but its making boost from 2500 rpm. Good luck with the whole project mate
Rings and bearings, clutch, flywheel and balancer have all arrived. Have taken them all to the machine shop to balance the rotating assy. Once done i can build the bottom end and give Machine shop the deck hight as to machine the heads. Seat is mounted. just on the CAMS website to research the fitment of second side intrusion bar. Once the bar is in we can complete the window net mounting. Also going to recess the floor for the exhaust to run in. All these little bits and pieces are more time consuming than first thought, but getting there. Also have to indent D/S chassis rail for extractor clearance. Have made solid aluminium engine mounts to eliminate engine movement as the drivers side is tight. Trying to organise a painter, have a friend coming to look at it on Friday, so might give the engine bay a lick first, then fit everything so it can go to the electrician. Pretty excited know as i haven't built an engine for myself in over 12 years, its always been for someone else or a customer. just cant wait to hear it. Post some pics soon.
Required removal of power steer rack and installation of manual steer rack on my car.
how tight is tight on the drivers side, my car decided to stop on the side of the road, cock it's leg and take a leak, so i might be looking at doing this sooner than i thought
Thats the idea Jas, once this things finished its gone.
Stuart, Stuart, Stuart.................... :ermm:
See what happens when you hang around these drag racing louts.
Get back into circuit racing mate, or at least your go kart.
  • 4 weeks later...
  • 1 month later...
As you can see Adrian has beaten me to the punch but thats his job as a mag editor.
car has had its first cote of paint, should be finished this week. painter is choosing a black for the turret, bonnet and boot. the yellow is vivid yellow off a hyundai of all things.
Thinking of coca cola for the top. still have to get bonnet and boot made. At the end of the day its all money. Picked up some Rays Engineering 17" wheels. Have split them as to have the centres painted and the dish polished. Alot of bolts in those buggers.
After dummying up the bottom end a few weeks ago only to find the main bearings clearances were tight, so sent the block away to have main bearing tunnel honed and crank re-ground. On re-measuring we have found that all is perfect and ready for assembily.
start pushing for my heads now. so all happening. Like to thank Nick from NM Autobody for the quick and thorough paint job.
Edited by BezerkR32
Was lucky enough to come across a gtr alluminium bonnet for a good price from SSS.
Happy as i know it will fit perfect, and know it is a shit load lighter than the GTST unit. So know its just the boot lid which JS Auto Imports is supplying and said to be ready this week. This will be the first time this car has had all the panels fitted sinse i have owned it. Pretty excited know as things are taking shape.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
