How exactly is the grunt the problem? Are you sure its not just crap drivers and poorly set up cars?
George isn't that bad of a slider and Im sure the setup of the car has had more work than yours or mine
why is the sr20 most suited motor for drifting ? = torquey midrange good "ark up'd ness" abiltiy when capped at power levels under 300rwkw
(lol i.e the way it ramps up onto boost hard)
check out Trent's SR20 for sale thread speaking about Cat's rb26 you'll see that linear power delivery and lots of downlow torque do not automatically make a D1 car
if slamming a ls1 into a shell made a awesome drift car everyone would be doing it hell the Japanese already would have already been doing it
balance and speed make a good skidder
ps can anyone point me in the direction of some credable ls1 engine and box weight specs?
  • Replies 812
I figured as much funny how ls1's wicked cause its lighter than a rb but when you take the box into account I doubt there's much if any difference between the two engine and gearbox packages
sites Ive found quoting around 200kg for a ls1 complete minus box
err box who knows?
anyway goodluck with it just don't expect it to own all first time out
Edited by 1400r
Box is out so ill weigh it tomorro. PS Whats a R33 5 speed weigh?
I cant remember saying i was building a drift car, the car was originally going to be a drag car, i said i would like to drift in it, as well as do some circuit work
and some skids and drags etc. But in saying that i have been carefull in how the engine was mounted, getting it as low and rearward as posible without sump mods, and have had some help from the Sureflow drift team on basic suspension setup for the amatuer, seeind thats what i am. not looking to win any trophies, just have some fun. I have a go kart 4 winning trophies. Believe it or not, the Japanese are not the be all and end all of motorsport.
Anyway, this is the project i have commited too and the engine is now at the machine shop.
Piston to valve clearance was 65thou with no head gasket, so arount 105thou. this gives us the oportunity to deck around twentyfive thou off to bring the comp up so the small cube V8 will develope more low down torque. Piston to bore clearance was a little excessive at 3 thou but good enough for a race car. Just waiting for a hone then ill slap it together. need all i can find to compete with these SR20s.
Edited by BezerkR32
  • 1 month later...
no, only a custom crossmember to suit the box, it is tight though. about 15mm around the top. even the shifter hole is very close. just have to extend it rearwould 20mm.
Car is at my brother in laws getting some minor fab work. mounting the seat, window net, a second side intrusion bar on the drivers side etc. should be finished in a couple of days. The bottom end of the engine is also ready to go, still waiting for the heads though. booked in to get wired in a couple of weeks. clutch should arrive this week.
just from looking at the pics the enigine seems to sit lower than the RB?
also nice work, i would be very interesting in doing this when my little RB goes bang. so there was no changes to the trans tunnel?
i believe the ls1 motor is 50 kilos lighter that the rb... have a dvd at home where there is a twin turbo ls1 in a 34... they call the thing Frankenstein's drifter. it also has the tremec box.... although these days the car actually has a stroked 6.6 litre ls2 with a masive twin turbo set up... but its making boost from 2500 rpm. Good luck with the whole project mate
Rings and bearings, clutch, flywheel and balancer have all arrived. Have taken them all to the machine shop to balance the rotating assy. Once done i can build the bottom end and give Machine shop the deck hight as to machine the heads. Seat is mounted. just on the CAMS website to research the fitment of second side intrusion bar. Once the bar is in we can complete the window net mounting. Also going to recess the floor for the exhaust to run in. All these little bits and pieces are more time consuming than first thought, but getting there. Also have to indent D/S chassis rail for extractor clearance. Have made solid aluminium engine mounts to eliminate engine movement as the drivers side is tight. Trying to organise a painter, have a friend coming to look at it on Friday, so might give the engine bay a lick first, then fit everything so it can go to the electrician. Pretty excited know as i haven't built an engine for myself in over 12 years, its always been for someone else or a customer. just cant wait to hear it. Post some pics soon.
Required removal of power steer rack and installation of manual steer rack on my car.
how tight is tight on the drivers side, my car decided to stop on the side of the road, cock it's leg and take a leak, so i might be looking at doing this sooner than i thought
Thats the idea Jas, once this things finished its gone.
Stuart, Stuart, Stuart.................... :ermm:
See what happens when you hang around these drag racing louts.
Get back into circuit racing mate, or at least your go kart.
  • 4 weeks later...
  • 1 month later...
As you can see Adrian has beaten me to the punch but thats his job as a mag editor.
car has had its first cote of paint, should be finished this week. painter is choosing a black for the turret, bonnet and boot. the yellow is vivid yellow off a hyundai of all things.
Thinking of coca cola for the top. still have to get bonnet and boot made. At the end of the day its all money. Picked up some Rays Engineering 17" wheels. Have split them as to have the centres painted and the dish polished. Alot of bolts in those buggers.
After dummying up the bottom end a few weeks ago only to find the main bearings clearances were tight, so sent the block away to have main bearing tunnel honed and crank re-ground. On re-measuring we have found that all is perfect and ready for assembily.
start pushing for my heads now. so all happening. Like to thank Nick from NM Autobody for the quick and thorough paint job.
Edited by BezerkR32
Was lucky enough to come across a gtr alluminium bonnet for a good price from SSS.
Happy as i know it will fit perfect, and know it is a shit load lighter than the GTST unit. So know its just the boot lid which JS Auto Imports is supplying and said to be ready this week. This will be the first time this car has had all the panels fitted sinse i have owned it. Pretty excited know as things are taking shape.
