  • Replies 812
fancy engine swap Phunkey....they are cheap to build, engine owes me $5000 without the manifold. boys tuned a 6litre a month ago, camshaft, valvesprings and tune = 310kw.
Sounds awesome Stu, pity my clubbie doesn't sound like that!
Your car makes me re-think my deision to stay with my SR and not just put an LS in there, would have cost me a hell of a lot less that's for sure, and would probably end up being more reliable too. :rolleyes: Oh, and I'd probably be able to drive it by now!
Mine has LS1 edit, stock sized-custom exhaust and a K&N panel filter and makes 233rwkw's... very easy power indeed.
i am very happy so far. I will be extactic after the SAU trackday if everything holds together and the car performs well.
so far its just a noisy (mind you good noisy) V8 that makes good power. still might be better suited for drifting, god forbid ive yoused the D word.
That is simply mint.... you should be proud Stu >_<
pretty cheap too, $4k will buy you a complete LS2 6.0l brand new. Has alternator, water pump, balancer, steer pump compressor, and coils, throttle body everything.
Since this build has started ive started buying street machine mag again..and keep noticing those brand spanking LS2 Crate motors or Fords DOHC 5.0L lol
    • Welcome to Skyline ownership. Yes, it is entirely possible parts websites get things wrong. There's a whole world of inaccuracies out there when it comes to R34 stuff (and probably 33 and 32). Lots of things that are 'just bolt on, entirely interchangable' aren't. Even between S1 and S2 R34's. Yes they have a GTT item supposedly being 296mm. This is incorrect. I would call whoever you got them from and return them and let them know the GTT actually uses 310mm rotors. Depending on where you got them from your experience and success will obviously vary.
    • Hi...a bit a "development" on the brakes. I spoke to the guys where i get brakes from...and they are saying that 296mm EBC are for R34 GT-T. I then went to their site: https://www.ebcbrakes.com/vehicle/uk-row/NISSAN/Skyline (R34)/ and search for my car(R34 GT 1998 - it has GTT brakes) and it show me this USR1229 number and they are rly 296mm rotors... So now iam rly confused... The rotors i have now on the car are 310mm asi shown... So where is the problem? Does the whole EBC got it wrong or my calipers are just...idk know what?
    • Oh What the hell, I used to get a "are you sure you want to reply, this thread is XX months old" message. Maybe a software update remove that. My bad.
    • This is a recipe for disaster* Note: Disaster is relative. The thing that often gets lost in threads like this is what is considered acceptable poke and compromise between what one person considers 'good' looks and what someone else does. The quoted specs would sit absurdly outside the guards with the spacers mentioned and need  REALLY thin tyres and a LOT of camber AND rolling the guards to fit. Some people love this. Some people consider this a ruined car. One thing is for certain though, rolling the guards is pretty much mandatory for any 'good' fitment (of either variety). It is often the difference between any fitment remotely close to the guards. "Not to mention the rears were like a mm from hitting the coilovers." I have a question though - This spec is VERY close to what I was planning to buy relative to the inboard suspension - I have an offset measuring tool on the way to confirm it. When you say "like a mm" do you mean literally 1mm? Or 2mm? Cause that's enough clearance for me in the rear :p I actually found the more limiting factor ISNT the coilover but the actual suspension arms. Did you take a look at how close those were?
    • @GTSBoy yeah sorry i know thery are known for colors bud those DBA are too in colors 🙂 Green will be good enough for me
