  • Replies 812
not sure of the break-up as i bought the lot as a package. total was $3800
Selby's bar, noltec bushes, bilsten shocks with eibach springs - I assume they are simply stock, powdercoated arms - is that right?
any idea what the coilovers are worth roughly?
thought i saw you cruise past, we were sexying here up for possible photo shoot on tuesday.
it sounds the sex, i got a peak at it drivin past ur place today :thumbsup: u need to go out terrorising one night haha
yeh they are standard arms. Just fitted bush kits in each end. Can get over 3deg neg on the rear which is way to much anyway and at the time i got them the new adjustable arms were still in the developement stage and were proving unreliable, and the standard arms are strong.
cool, thanks. so they are stock suspension arms then?
yeh, probably should keep both hands on the wheel instead of one out the window ya noob.....my arse hole got so tight when you were heading towards the concrete........rofl
car sounds and looks sweet! driver should stick to drag racing I think.... :thumbsup: teehee.
yeh, all set..........i think......getting a bit nervous now actually.
have to swing a spaner over it 2moro and change the running in oil and check other levels but thats about it.
Lookin good Stu!! All good to go for Friday i take it?
was planning to do the above things today after the photo shoot for Boost Magazine but after being turned away from the local kart track we made our way to the local Nissan dealership to shoot. We shot pretty much everything we had too when the manager came out and told us we couldnt use anything as the dealership could not be affiliated with an import. 3 hours wasted. Was lucky enough to be allowed to do the shoot at local wrecking yard (Dapto Pick A Part) who were more than happy to have us there. 2rismo may be able to shed some light on what issue it could be in.
fyck that sucks. probably would have been wise for the magazine to ask their permission before spending 3 hours using someone's commercial premises as a background though... :(
hopefully you got some good shots though. :happy:
nah Baron we were told it was all good, then pulled the pin. we were actually on the lot with all the cars. it was kinda cool, but i think it worked out for the best as the photographer was happy with the second lot of shots.
Should be in issue 10 or so. Baron, my photographers aren't amateurs. They have manners and use them. No way they would ever use private property without permission just as they didn't in this case. It is funny how quickly people forget though. I reckon Stu kept that particular dealership in shiny new Pulsars with all the import parts he's bought over the years. :(
never mind, we love Pick A Part in Hamelton St Dapto.
Should be in issue 10 or so. Baron, my photographers aren't amateurs. They have manners and use them. No way they would ever use private property without permission just as they didn't in this case. It is funny how quickly people forget though. I reckon Stu kept that particular dealership in shiny new Pulsars with all the import parts he's bought over the years. :bunny:
what bastards! yeah I did think it strange for the guys not to have tee-d something up before hand. bad assumption on my part. >_<
what clowns. give permission then take it back. not to mention the fact that photo shoots like that do nothing at all to hurt their brand. they should look at it as free advertising. do they want to endear themselves to young, hip demographics that have disposable income or not? looks like not. very close minded. and typical of the imports are evil attitude yet they are happy to make money flogging us parts for them...
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
