yeh, think they are heavy. i know yella terra re-designed them so would be interesting to see the new ones.
i will be putting a set of Harland Sharp rockers this time though.
Any idea what the issue is with the roller arms? too heavy and causing valve float / bounce?
  • Replies 812
got through a bit of work this week, removed rear boot latch and fitted some bonett pins on the boot lid to make it easier to access the fueltank and eliminate the risk of loosing the key and not being able to open the boot.
Purchased a GT style rear wing, 1500 wide and sits just over 300 off the boot lid. Great fathers day present, thanks girls.
have began lowering the drivers seat which we should finish tonight. Also going to lower the fuel tank to drop the centre of gravity as it was advised this could aid in helping with handling in the rear of the car.
Still waiting for the front bumper. Might give the air ducting/engine cover a crack on the week-end.
Your build is mint and i didnt want to be critical of an awesome build, but i was left wondering why you threw the fuel cell up high in the boot. Throw back in the std jobbie, or GTR as i am told they are plastic and lighter, ...or better yet make up a 30L smaller alloy jobbie that sits under the car but in front of the rear axles...perfection.
I am reading all these build threads whilst stuck in a hotel room and so keen to ge tback to Aus and getting something going
i guess i did it this way as the tanks are cheap and it was easy to modify to run the internal pumps and because ive set up to many fuel systems on drag cars lol. If i run a standard tank i would have to run a surge and i just wanted to keep it simple. My setup only runs a feed, pressure is regulated at the tank.
Ill drop the tank into the wheel well and the sump will hang through. Its minimal work to do this and i wont have to re-plumb anything.
i
OK, the wing is on......and im not sure about it. maybe it will grow on me but at the moment i think its ricey, when i see it all i can think of is honda civics or mitsubishi lancers. i hope it gives the downforce it looks like it should or its going to get the ol heave ho. Anyway can always sell it to a drifter lol.....which makes me wonder why they have wings anyway.
im still waiting for Vin Diesel to climb out of it....
The wing is glass with a wrap. The uprights are cnc machined alloy and pretty serious though and it has large endplates.
i bought it second hand over the net. Dont know who makes it....could even be a custom job but not sure.
It looks alright Stu, Is it carbon?
also any idea who makes it / sells it?
Started on the air dam today. Used a fibreglass bonnet outer skin, marked it out and slowly got it to sit around the intake.
still have to glass up the sides and fit mounting brackets but you can get the general idea...
ha ha, driven a commodore lately? with the amount of off the shelf parts and interchangeable parts available for a Nissan, let alone the body shape of the R32 which is small, and arguably the best ever made, the combination was good. And im not sure what a Commodore has to do with it, if i had the coin i would have bought a Vet.
The thing is i always wanted the Skyline, the engine popped up by chance. Ive owned one taxi and ill never go back....
After all this man why did you put a v8 into your 32??? shoulda just bought a commodore if u want a v8!
got intake dam back from fibreglasser today and he had done a top job, we trial fitted it and it was near perfect.
finished trimming the sides down and fitting dzus fasteners tonight. It will do for sunday, ill get it painted after that.
also fitted passenger seat and harness for the track day.
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
