Looks like I'll have to stick the ol thumb out for a ride on a SAU cruise then..... ;)
sau flowing through you, yeeesss (yoda voice) get my liscence back really soon just hang me a pm dude on any events ya wanna be involved in and im happy to help! altho im sure your beast would be welcome as most sa members know of you if not know you. ;)
*edit* just stick a couple sau stickers on it like mattys red tow beast :P
Edited by jenkies
to get more power out of a stock engine would u just need to get forgies?
This is more of a forced induction topic, but the answer is NO
Forgies (forged pistons) will only be a small part to make the engine reliable at higher power figures
(ie you dont need forgies unless you push big power figures and want to keep the moror in 1 piece for more than a year)
i never wanted to put ne stickers on my car (mainly the shopping list!) but i figured the skylinesaustralia one on my lil side windows couldn't hurt. besides, there's too many black skylines around ppl mite mistake me for someone else...
All the more reason to make it look different to the rest of the sheep.......
Can anyone tell me where i can get a f**king manual on females because after tonight i DONT f**king understand their ways at all :cheers: Its like im a magnet to the freak shows of adelaide
I always say that males are like a simple big block V8, easy to understand & always ready to go.............a female is like a complex ferrari engine, close the bonnet and walk away while you still can :cheers:
by chance does anyone hav a PDF form of the Apexi RSM technical and product manual?
I downloaded the english version from the Apexi USA site........but its for the old school RSM
The Japanese site had the right manual, but alas its all in japanese
Trying to logically work out what we did wrong in the wiring yesterday for the speed not to work (worked off a setup map that had 2 versions...........RSM normal or RSM overriding speed cut, we used the latter).
Mind u it felt great to go for a quick squirt in the 31 last nite................the headlights are awesome :cheers:
nah not really steve, thats more for an installation into a lexus :cheers: but cheers anyway
someone was saying the other day that theres a member with a digital copy of it (or access to it)
*edit*
got sent a copy by a mate from 31 club..........he's got a whole heap of manuals like that on CD :cheers:
Edited by Matty 31
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
