thats not entrily true there is a mod you can do
GWW can bench test it i imagine most other workshops can too
ive booked the car in for dyno day @ grahm wests today.
the misfiring is not as bad anymore, drove the car to uni and back, then for another test run and seems ok. there's a split second of misfire but shouldn't be too much of a problem. Ill be getting the silicone insulator on the coils over the weekend and my afm cleaned up.
when i get my exhaust done ill look in to getting a toshi map, or an safc... don't want to spend thousands if all i'm after is not too much more power than its already making. don't want the car for straight line speed, want response and a steady power band.
http://www.skylinesaustralia.com/forums/Ca...ans-t68174.html
good read, SK offers some bang up advice.
this is the link you lot are after http://www.skylinesaustralia.com/forums/Ca...html&st=20#
So i have read up quite a bit on the use of a catch can today, and i came to the conclusion that its only good if the catch can is somehow vented, which is not legal. Another conclusion is that my setup is doing sweet f**k all, and am considering selling my catch can to plan for the future. 70 bucks, takers :P
So i have read up quite a bit on the use of a catch can today, and i came to the conclusion that its only good if the catch can is somehow vented, which is not legal. Another conclusion is that my setup is doing sweet f**k all, and am considering selling my catch can to plan for the future. 70 bucks, takers :D
We have a for sale section you know :P
:):P:D
Edited by RubyRS4
At work today thinking about next yr. Wondering if i should save up spend 10k on a engine or spend a month holidaying in Japan.
hmm hard choices.
+1 Japan, been there twice and look forward to another visit sometime in the future.
I have sacrificed my washer bottle for intercooler piping. What else will fit in that section? Having a daily requires me to use it from time to time when rain dries on the windscreen.
my mate can fabricate ya a washer bottle if ya want one there
yes please!
have to work out a time when he's free, and he can look at the space ya got. does his fabrication work outta his dad's shed at virginia (where my cars are being stored, and is the same guy who made my trailer)
I would also like a washer bottle that fits in despite my ic piping. I assume if Damo got one made up it would fit my car too? I can supply my oem washer bottle motor if he wants to integrate it (which would be preferable).
I had to lol
After Gates Timing Belt + Tensioner Kit for RB26 before Friday.... new only... pst me if you got one
-D
is that like
[quiet voice]pst hey buddy i got a gates belt if you want it (looks around) going cheap (looks around)[/quiet voice]
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
