Fair point all, I think though if all topics that are not "on topic" are placed in the wasteland we are just going to get everyone confused, and if you are reading something interesting it will get lost in all the other random posts, i haven't logged on here since last night (broadband down at work) and there is about 4 new pages just today! if i wanted to find something particular it certainly would get confusing.
I think having a subsection for something like "general SA members banter" would be a problem as we would have a subsection for a subsection, but things like "computer jargon" and "the pregnancy thread" "jokes thread" are a good read. Maybe people really need to have something that is interesting or important to SA people before starting a new thread maybe?
Discuss!!
Karl, I personally don't mind threads like Jokes & Computer Jargon, it's just some of the other crap that gets started that leaves me very cold and really wastes my time.
A good example of a recent thread (where I contemplated giving about 10 members a holiday) was that 9 page effort (all in one day) with 100 IBTL's and other crap in it.....I spent over 1 hour reading thru immature dribble, time I could've spent with my kids.
So how do we handle the crap threads and who calls the shots as to what's crap and what isn't........someone's rubbish can be someone elses gold, so I'd be dammed if I deleted and dammed if I didn't......how do you please everybody?? :P
Dave, if you want a hand doing the pads, I'll do them for you, gimme a call or message on 0431596795 :P
+1 for Helso doing your brakes Dave
did a great job on installing 4 new rotors and pads on my 33
pity they sssssssssssssssquell like f**k but thats not his fault
if any1 here can help me with a questions..may sound stupid but meh
im looking for GTR seats and wanting to know if any would fit into an R31?
yes, yes they can. pm matty t, hes a 31 nut, he'll be able to steer you in right direction... eventually.
the weber is at auto carby services getting the delux treatment. got a set of TRX meshies coming in on the weekend, and the fuel tank is almost keeping fuel inside it.
that will be all sorted soon as, all that will be needed next is getting some exhaust place to plum up between the turbo n the carby
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
