Fair point all, I think though if all topics that are not "on topic" are placed in the wasteland we are just going to get everyone confused, and if you are reading something interesting it will get lost in all the other random posts, i haven't logged on here since last night (broadband down at work) and there is about 4 new pages just today! if i wanted to find something particular it certainly would get confusing.
I think having a subsection for something like "general SA members banter" would be a problem as we would have a subsection for a subsection, but things like "computer jargon" and "the pregnancy thread" "jokes thread" are a good read. Maybe people really need to have something that is interesting or important to SA people before starting a new thread maybe?
Discuss!!
Karl, I personally don't mind threads like Jokes & Computer Jargon, it's just some of the other crap that gets started that leaves me very cold and really wastes my time.
A good example of a recent thread (where I contemplated giving about 10 members a holiday) was that 9 page effort (all in one day) with 100 IBTL's and other crap in it.....I spent over 1 hour reading thru immature dribble, time I could've spent with my kids.
So how do we handle the crap threads and who calls the shots as to what's crap and what isn't........someone's rubbish can be someone elses gold, so I'd be dammed if I deleted and dammed if I didn't......how do you please everybody?? :P
Dave, if you want a hand doing the pads, I'll do them for you, gimme a call or message on 0431596795 :P
+1 for Helso doing your brakes Dave
did a great job on installing 4 new rotors and pads on my 33
pity they sssssssssssssssquell like f**k but thats not his fault
if any1 here can help me with a questions..may sound stupid but meh
im looking for GTR seats and wanting to know if any would fit into an R31?
yes, yes they can. pm matty t, hes a 31 nut, he'll be able to steer you in right direction... eventually.
the weber is at auto carby services getting the delux treatment. got a set of TRX meshies coming in on the weekend, and the fuel tank is almost keeping fuel inside it.
that will be all sorted soon as, all that will be needed next is getting some exhaust place to plum up between the turbo n the carby
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
