I want HIDs..
Anyone got any they wna palm off?
We both buy some and you can do it for me.
You both buy the kits and i'll install them for ya. Easy as to install, did mine on the R33, took me a 2-3 hours to do, but i had no idea what i was doing....now i do :).
Would anyone recommend having the lights realigned since changing to HID's?
hey Matty, amazing how a bit of rubber can bring the tuff look out in a truck........4X4 + highway terrains = ghey!!
definitely.....however all terrains works for towing and daily driving. at least the ATZ 4 rib are a tough looking tyre that performs well without being noisy
i is bored.
+1
Random note, narva is awesome. They make these factory looking dash switches that fit in most standard dash openings. Had to fix up a few things for my spotties (plus preparing for the extra lights im getting in a few weeks), and i bought a few of these (excuse the holes in the dash, have to make a trip to nissan and buy a few blank plates):
and illuminated when high beam is on (right hand is the only one that has anything connected at the moment)
Which kit should I go for Abe?
Links? Prices?
Really comes down to how much you want to spend and brand you prefer. I myself went with a Bosch 6000k HID kit from the group buy, pictures here from my car blog - near the bottom of the page. I only went with Bosch as most of there other products are quite good, i went with 6000k as they aren't yellow and aren't too blue (illegal).
Group Buy link with pics. - I believe it has closed, but he may start another one in the next few weeks/months.
Would mine hitting you up soon about that install.. One of my headlights is out at the moment so I kinda want it fixed asap. But I would really love to get HID's.
Anyone know how to get the main headlight globe out of a R32 GTS-t? I can't work it out.
hey peeps...have a major problem....got a hole in my fuel tank...on the stag cruise....changed it over...put the same pump back in...everything exactly the same except its a different tank...i mean its from a 31 sedan...it just hasnt got a hole in it....started up fine....drove to the ATM and servo fine.....went to put my foot down from the lights and started missfiring through the AFM...wouldnt rev..even though it would spool....it would only move if i lightly used the throttle.....any ideas people??? all cooler hoses are in their places...all plug leads are where they need to be....the tank was cleaned out...and so was the filter mesh on the bottom of the 040....im all out of ideas and very close to putting a match to this f**king thing
Might be a dumb Q, but is the tank from a non-EFI 31/pintara? I know with most of my previous projects, for ease of engineering and getting Regency approval for SR and CA transplants into a 1600/200B, an anti-surge bowl was grafted into the stock fuel tank. Beats having a swirl pot for the cops to see.
If its a stock non-EFI tank, then the fuel pump may not be adequately picking up the fuel. Its a guess, but my 2c worth.
Maybe also a ventilation issue with pressure in the tank?
Edited by RubyRS4
as for the hole in the fuel tank, the best way to fix it aside from getting some brave kent to weld it is to use natural flagrance free soap. Scrub it on the hole while there is fuel in there, the soap reacts with the fuel and stops up the hole better than that putty crap u can get from the servo.
i thought it was dubious, but i tried it on the rollas fuel tank and it works a treat. The guy that i got the idea from has been driving around in his ae86 with his tank fixed like that for the last 2 1/2 years :P
    • I strongly recommend anyone playing with cars chasing anything electric, get a basic understanding of using a DMM, and about 12V DC systems. They're REALLY easy, you only need to know V=IR and how to apply it, and you can work out what your readings should be doing. For a simple check on a light bulb, you're looking for 12V at the positive to the light, a near zero resistance to ground, and then for a small resistance across the globe when unplugged. If one of those values isn't right, you won't get what you need. Now if they're all okay,and you then plug the light in, and it still won't work, you now do a voltage check across the globe positive to negative. It should effectively read full battery voltage. If it's not, especially if it's quite low, the age old V=IR starts to be able to be thought about, you now know though, for the current flowing, there isn't much voltage for the given resistance, but the rest of that V has to be dropping somewhere else. So now do a voltage check from ground of globe, to ground of car, then do voltage check from positive of battery, to positive of the light connector. Things like a high resistance in a wire/join will start to "steal" voltage on you. So now step back through which ever wire, until you find the voltage drop is non existent, you're now before what ever is steal your voltage for example.   There's plenty of YouTube videos, but really worth understanding some V=IR, and doing some even theoretical numbers to start to understand it. Then you'll know what the DMM is telling you.
    • Is Jackie home by Friday?
    • Item 10: Tech Edge wideband sensor interface and display. You’ll need to buy a new sensor. $150. Item 11: part of a Willians 5 point harness. $40 Item 12: OS88 gear display. No need for it now, my PPG sequential came with one. $30
    • I took it out, even though I knew I probably don't know what I'm doing other than looking for power signal lol. Lesson learned here I guess, even if it looks normal, worth checking as it only takes a few seconds anyhow. And maybe disconnect the battery, even though really shouldn't have to.
