umm this is gonna be probably sound dumb for u turbo peoples
but if i get a stock r33 turbo, will i have to get a stock r33 bov to go with it or can i get a r34 one if i cant find a stock r33 bov?
Lol cara the Blow off valve its self has nothing to do with the type of turbo you are running so Just use a R34 BOV or whatever you can get your hands on, Maybe get an aftermarket one that lets it go to the atmosphere so you dont have to worry about modding your air intake to suit the plumb back factory style.
block it and make it sound like you got 100 pigeons stuffed under your bonnet....btw cara may i ask why you getting a R33 turbo and not something bigger as my stock turbo makes 211 and then sort of runs out of puff towards the end...and no point turbo charging a NA, only to be limited by the turbo......get something bigger for around 300+rwkw mark.....well thats at least what i would have thought :laugh:
ummm... because she is turbo charging an NA??
i'm presuming you dont know much about compresion ratios?? turbo car has a compresion ratio of about 8.5:1, NA is about 14:1, meaning that you cant actually put a massive turbo and/or run much boost on an NA car... its all to do with things exploding =P
Cara, if you haven't done so already, keep in mind the Neo motors have a longer throttle body, so the intake piping to which the BOV is attached to is shorter than your average 33. Therefore the 33 intake piping wil not suit your Neo. Need a Neo DET pipe.
:laugh:
I know its different compression ratios etc......i would really think that it would be worthwhile just getting a DET motor instead of tweaking the NA DE.....and try flogging the DE motor off or use it for spare parts :laugh:
very nice 32 buddy boy^^^.....same BBS wheels as my old bus
you have the coolest job ever Pete
not really Carl.......probably would be if I could charge 1 Gazillion Dollars per year!
LOL Fishy, I think you're thinking of Matty's & my diesel trucks (although they're alot higher than that)....but yeah, comp ratios are higher on NA no doubt.
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
