Life Story entry #326:
Happy I got the Stag back. The box feels much better. Gotta head south to run a few errands today. Might head home via the hills on the way back :)
bargain basement. this + control box + reversing camera for 165 delivered to my door
win
oh yeah, gotta fit it yet haha
wwhhhyhyyyyyyyyyyyy matty whyyyyyyy. i used to sell that same model at autobarn for 130 on sale. shoulda come to me if you were ebaying for something like that. coulda put together something for under $100. Did it come with the wireless camera on the bracket that just bolts over your number plate or did they give you a proper cmos wired camera?
came with bracket to mount the screen, wiring (with 2 inputs), remote control (f**k knows why i'd need that), 10 metres of cable and a small sized cmos wired camera. im getting a CCD camera for the trailer when i get round to it.
ah yeah sorry Jack. I am after a stand-alone screen that I can have a fibreglass shroud built to custom mount it on a dash. Planning on plugging an EeeePC/Acer Aspire One into it to run full time consult display tools from ODBII. Resolution needs to be around 1024x600 or so, and needs to have a VGA conector (and USB connector to run the touch screen obviously).
Sounds sexy Andrew, will fit the new car quite nicely too!
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
