Nothing wrong with saying "Mr Squiggle", just confused is all.
I have been testing centrafuse on my laptop, which will become my carpc. I am not too sure which to use though, i want something that is going to be easy to get working with the haltech software so i can get the gauges etc working.
Centrafuse or Ride Runner will give the best compatibility for that sort of stuff imo, but rr is butt ugly. Is your laptop one of the ones that turns the hdd off if it detects a bump (most new ones do)? Cause even around the city streets it's enough of a bump and totally killing my music video playback and lagging software. Thinking maybe a mini-itx setup is in order.
Edited by nicr4wks
LOL Matty, where did you go?
Just quietly, we need to convince Luke into getting a 4x4.......he's apparently contemplating the idea!!
a lil spot out near edinburgh. have to show ya sometime........give the 200 a nice brown hue to it
just went and cleaned it after work at the big bucket at bedford park. mental note, dont use the very right hand wash bay unless they've cleaned it up haha
1 hour and 28 bucks equals a clean car (engine bay and outside, and MOST of underneath that i could get to). The rest i'll get on friday when i chuck it thru the auto wash for its weekly clean
anyone recommend a wireless key board and mouse?
Logitech or MS like Luke says. incidentally the MS keyboards are all made on logitech fabs
I like a wireless mouse and a wired keyboard, mainly because the logitech g15/g19 series are awesome and a standalone mouse usually has better resolution than a combo wireless mouse
and as for car pc's, you'll want solid state drives all the way, but im not sure if the eee would be the best bet for a permanent installation - theyre good in the glovebox but if you want a permanent solution then a dedicated car pc or a mac mini with aftermarket ssd would do the job quite admirably. Best mount point would be either under a seat or behind the rear seats between the rear strut towers and just run a db25 vga and usb to the front to the touchscreen head unit
-D
Some cock tried to steal the 33 on the weekend. :D
A club lock and alarm kinda ruined it for them :worship:
I'll remember to turn on the surveillance to the outside cameras from now on ... so I've got an idea of who's trying. :)
I have no idea if it will do that, plus a HDD skipping would hardly miss much/if any of a song or movie. The laptop i got is a Acer 5315, got it free from work, i am going to upgrade the cpu in it when i can be bothered pulling apart a HP at work.
-D
I am going to be placing the laptop in the spare wheel well, may also move the amps into there aswell, and have a mdf/false floor in the boot. Then run a VGA and usb cable tot he front of the car for the touchscreen.
Does anyone know much about ET pulsar's? a friend of mine has one that isnt working and is wanting to sell it, i am thinking of buying it and fixing it.
yeh i do a bit, had a blue one with a high mount high flowed t25
the gearboxes are crap especially reverse, and the factory computer is also crap as it is located under the passenger seat which is easily knocked by the passengers feet which in turn pulls out the loom
other that they are a great little FWD car
Some cock tried to steal the 33 on the weekend. :down:
A club lock and alarm kinda ruined it for them :D
I'll remember to turn on the surveillance to the outside cameras from now on ... so I've got an idea of who's trying. :worship:
damnit, you sprung me :P jks
Yeah my mate was saying that the ecu was crap, i reckon i'll buy it and fix it up, i want a car i can pull down and rebuild easily so i can learn, ain't gonna do it with my line, that's my daily. I may then sell it to a mate for his 1st car.
Thats not a bad idea, the only thing I would be concerned about is the heat generated from the amp and the computer. you may be better off putting the amp in a conventional position like on the back of the rear seats or under the passenger seat - otherwise you might need to think about mounting a fan inside the wheel well under the false floor
Jack88 knows a great deal about maximising position, I suggest you give him a msg and send him some pics n see what he recommends
+1 for his build quality too
-D
Edited by Dohmar
-D
Thanks for the suggestion, gives me something to think about now. I was going to use the guys at Strathfield at Noarlunga for the install, but i'll message Jack later when i am going to do the install.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
