seen it too, dont think it is shaun. Its been a spot on the 31 club before but dont think they're a member there either. what time did u go past it?
I went past there about 7ish when the second fire truck was getting there and there was police and an ambulance
Hey Pete,
I had a look around the yard at work today and found a 2m piece of that 100x40 beam that you need for your retaining wall. If you need some let me know and i'll drop it around.
well ive pulled my car apart lol got the rocker covers off and all and gonna go start cleaning it all up ready to paint. found out something interesting however, the airbox that is attached to the bit that goes into the throttle body, was melted underneath!!!! it had been touching my extractors :D explains quite a bit on why she is always either running rich or leaning out ....gonna try and get a nice shiny pipe to replace the black box and tidy up my engine bay a bit :domokun::blink:
Just be careful, that black box is an air resinator. May have to get your tune adjusted once its gone and its one smooth pipe from the AFM to the throttle body
hey Cara have you started sourcing parts for your build? I have a set of brand new Tomei heavy duty valve springs to suit a Neo here for sale $350. Retail $700. Else I am going toput them Ebay and they will sell for more.
Hey Pete,
ooooh yes please......let me know what I owe you for it bud, thanks.
yeah very sad bud.....classic case of 'money can't buy happiness'.......although it helps :P , but there's more to life me thinks.
On the weekend i went and stayed at my sisters place in Truro to watch the 24 hour moto enduro. It was pretty good to watch and cos my sister work's for the one of the land owners i got to thrash my thumpster around one of the sections when the riders had been through :P
yeah it is awesome for 4x4 action, wish my sister would let me use one of hers. If i had one the farmer would let me use the land if i wanted, I can take my bike up there anytime he said. He only owns 6000 acres :P
well gonna have to have her re tuned cause i not sure how long that box has been melted for!!! :P
all that sort of stuff was in my quote from Chris Milton Engines for when i get it done,. but thanks heaps anyway :)
sorry thought id share this 1 out the car crushing
i used to be a stupid driver & grew up & i see the answer is simple, make the laws maniditory so no judge can let people off with lighter sentences its this simple, people know if they look sorry & have a good lawyer they will keep their license one way or another but with manitory enforcement theres no chance & they will know what the punishment is no matter what. also maybe the law needs to add ideas like sentencing people to the military to learn.
Posted by: Lyndon Bushnell of elizabeth sa 1:59am July 04, 2009
your still stupid its just now your a hypocrite as well. no wonder you live in the gheto. how about we enforce these rules you speak of and as you have just admitted to conducting in hooning activitys we'll crush your current car. clearly you are just as much a criminal as any other hoon. following your logic of "they dont learn" im sure your still hooning today.
n military wtf crack you smoke, obviously cheap elizabeth manufactured
Edited by Inline 6
China's roads are notoriously dangerous. Last year, nearly 73,500 people died in road accidents in China last year, or more than 200 fatalities per day, according to police statistics.
wow.
wow.
I dont hear them bringing in laws to crush cars now for people who have had a prang this year lol
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
