Ta Dion.. I knew the committee was up and running..Have been invited to the Dyno Day but cant get down there in time :)
I think I have your email addy. I can forward you a copy of the minutes from our last meeting, just to bring you up to speed on whats been crackin and whats in the works ;)
Looks like some pretty nice 4x4 country Chad.......I see Matty's eyes light up, lol
oh yeah, i just looked at them and had to double check if i still had the mickey thompsons on the car haha
and damo, you're an effing legend man! you know why ;):)
