sweet. ill check em out on my next day off. rough idea on price? (yes, i know their number is right there. :( )
im thinking jdm 440's might be a tad small. need some headroom for more power...
... not that ill be aiming for more power, because modifications are bad and illegal, and kill people, abort pregnancies, crush kittens, and club baby seals. :P
There are some problems with high flowed injectors not having a good spray parttern and therefore bad atomisation.
When you can get 500>550cc for around the $300 mark why bother.
http://cgi.ebay.com.au/Fuel-Injector-SUBAR...p3286.m20.l1116
Give this man a beer.....Dave i would suggest that you seriosly look into aftermarket injectors instead of highflowing your stock ones mate....i have also heard that highflowed injectors dont work as well as its expected to....NISMO ftmfw
Dave have a look at these guys in the US as well.
http://www.deatschwerks.com
i have not heard of any issues with there injectors as they are all flow matched and i bought some off of the already and it was great service.
About $450 delivered for 550's at the current exchange rate.
Cheers
Edited by Evil34
I have today off, the mrs is at work and I'm fkn bored waiting for the washing machine to finish a load so I can hang them out.... then what? Any ideas....
clean the part of the house your wife hates cleaning the most. give your skyza a tickle, little detail. put on a roast so its ready when the mrs gets home. ey presto youve turned a day off into 2 weeks of freedom :P oh and if u play guitar have a lil jam to some of ur fav songs hahah
I do 99% of the cleaning anyway, she won't be home until around 10pm, I have all the freedom I could ask for and I just spent the last 4-5 days on a new song that I no longer like or have an inclination to continue production on.... skyza?
Next :(
Does anyone here know anything about plastic forming? I mainly want to know what plastic to use and where to get it. I am thinking of using acrylic sheet, but i think that may be a bit thick.
Next :P
way to shoot a man in the foot lol.
skyza, skyline.. haha i get it now "give your skyza a tickle"... almost sounds suss
Sorry didn't mean to.... I thought it was sus, thats why I asked :P
If bom tells me it ain't going to rain for a few days I might just go and wash the skyza
http://www.bom.gov.au/products/IDS10034.shtml
Err... maybe not!
I am pretty sure Dave that SR's are side feed....if so then the Nismo 555 or 740's would be the way to go mon ami
I've been looking into Nismo injectors also and RB25 are same as SR20 = side feed. :/
