Decided to upgrade all the belts on my Stagea. Got a complete set of Gates belts coming: timing belt, water pump, ps pump, alternator. Guess what I'm doing next weekend? :D
How much and where from? I am thinking of replacing my timing belt when i have my mods done, my as well do all of them at the same time if it isnt too expensive.
Does anyone know how to remove plate safe screws??
Just trying to re register the car and replace the old plates.
:P
I have an array of sockets/bits for safety screws (about 30?). Which one do you need?
Thanks for the offer Ruby, but I called RAA earlier (they provide plate safe screws) and they said apparently they are non reversable screws.
Im just on my way out to my Uncle's now he is going to drill them out.
Thanks for the help people who responded
much appreciated.
    • I refer you to this thread on PF, by someone who knows what he's doing. Paints a good picture of the humble AD09.
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 😛 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
